Hamilton 975
IowaWatchGuy
Dec 24, 2004
26
Hello to all and a Merry Christmas!
I have a private lable Hamilton 975 pocket watch. What I was wondering is how rare are two-tone 975's. The actual plates on this watch are two-toned not the screws like some call two-tone. I have never seen another like it and have only seen one 974 this way. Any help is appreciated.
Thanks!
IowaWatchGuy
Dec 24, 2004
26
Thanks!
Dr. Jon
Dec 14, 2001
6,057
621
New Hampshire
According to my handy dandy Hamilton guide they made 68,000 pendant and 31,573 lever set, in regular and gilt trim.
Rhett Lucke
Board Secretary
Director
Feb 18, 2001
2,056
827
rrstd.com
Two Tone 975's with Hamilton or private label markings are somewhat scarce.
If possible, could you post a picture or full description of the dial and movement (including serial number)of your watch?
Rhett
Rhett Lucke
Board Secretary
Director
Feb 18, 2001
2,056
827
rrstd.com
Iowa,
Thanks for the information. I have seen a number of 2-tone 18's Hamilton's with the same name (some with fancy dials also), but this is the first 16 size.
Rhett
Don Dahlberg
Aug 31, 2000
3,425
17
According to Hamilton records taken from Factory Production Book the total production of 975 pendant set was 70,500.
"Of the above total - 9397 are recorded as Gilt Trimmed
263 are recorded as Spedial Finish
200 are recorded qas Union Special
290 are recorded as 'Thor'
1,924 are recorded as being made up with gray bridges to allow for engraving the jeweler's name or speciql trade name instead of the regular engraving."
The total production of lever set was 31,680
"Of the above total
8,295 are recorded as Gilt Trimmed
106 are recorded as Special Finish
1,520 are recorded as gray bridge.
The Hamilton records go on to say
"'Special Finish' watches, in both Pendant and Lever Set, were made up with the regular trimmings (steel screws, regulator parts and lettering in black) and with gilt trimming (gilt screws, regulator parts and lettering gilt) and it was impossible [to] defintitely segragate these so that no attempt was made to keep the "Special Finish' as a distinct item - some are included in the 'Regular' and some in the 'Gilt Trimmed'."
So it appears that "Gilt Trimming" refers to the gold plated screws and regulator. "Gray Bridge" refers to special private labels engraved on the movement. "Special Finish" refers to special damaskeened patterns, not necessarily a two-tone. The "Thor" was a pattern that I have seen in true two-tone. The "Union Special" watches were "made up for H. F. Hahn & Co., Chicago. They were usually made up in hundred-lots,- with gilt trimings and double sunk dials and were charged at the regular price for a watch with these additional features."
The pictures shown by IowaWatchGuy are not clear enough to see the pattern.
Don
IowaWatchGuy
Dec 24, 2004
26
Hopefully this picture is a little clearer for seeing the demasking on the movement. It appears like a checkerboard demasking with little snowflakes in the pattern also.
Don Dahlberg
Aug 31, 2000
3,425
17
It is still very out of focus, but it does kind of look like a checkerboard pattern which is consistent with the Thor. Still hard to see.
Don
IowaWatchGuy
Dec 24, 2004
26
Thanks for all your help everyone!! I will try and work with the camera a little more this week when I am not so busy and try and get a better picture yet. Mabye I will even work with it in photoshop......we shall see.
Thanks again to All!
Kent
Gibbs Literary Award
NAWCC Silver Member
Aug 26, 2000
18,489
1,872
IowaWatchGuy:
Try taking the pictures from a little further away. Your camera may not be able to focus as close as you've been taking the pictures. It'd be helpful if you can use photoshop to crop the pictures down to just the size of the watch. That way, the file sizes will be a little smaller and they will load up faster.
Good luck,
Kent
Topic related ad experiment
