Hamilton 4992B used by the Naval Observatory
Discussion in 'American Pocket Watches' started by Jim Haney, Mar 28, 2015.
  1. Jim Haney
    Jim Haney Registered User
    Sep 21, 2002
    5,036
    Working the farm, Garden,horses, goats, chickens,
    Decatur, TN.
    Marvin Whitney built these from a Hamilton 4992 B Military watch to use as a measuring tool at the Naval Observatory.
    The Observatory was using this instrument to see what error was in the TIME signal between the Station in Beltsville, MD (Washington, D.C.) WWV, and the location it was received in, Colorado or anywhere else. The error would be caused by interference in Radio signals in the atmosphere.
    This was the time signal and it had to be correct without any error. They broadcast it in several Megacycles 2.5,5.0,10.0,15.0.
    Some info from Google,
    https://books.google.com/books?id=xAVp8cnrEWMC&pg=PA116&lpg=PA116&dq=WWV+Megacycles+2.5,5.0&source=bl&ots=O2Aet-XLgl&sig=M2ovNspWKfZnEfEo9fLIrZBgMck&hl=en&sa=X&ei=0vsWVeKeEIedgwTV2oDgCg&ved=0CDgQ6AEwBg#v:^nepage&q=WWV%20Megacycles%202.5%2C5.0&f=false
    I got this from a Commander Al Betters a friend of Whitney's and he gave me the letter than Marvin wrote to him presenting this as a gift to him. He supplied photos to Whitney to use in the book Marvin was writing at the time. "Military Timepieces, c 1992.
    Cmdr. Betters was a Navy "Frogman" and his pictures are on page 580.
    I have seen 2 others, one owned by Military parts guru, Larry Crutsinger, http://www.hamiltonparts.com/ & fellow collector Fred Hansen.
    DSCN3380.JPG DSCN3378.JPG DSCN3379.JPG DSCN3381.JPG DSCN3382.JPG DSCN3377.JPG DSCN3383.JPG DSCN3384.JPG DSCN3376.JPG
  2. s. smith
    s. smith Registered User
    Oct 13, 2006
    582
    Jim very nice it,s a beauty.
  3. Paul Regan
    Paul Regan Registered User
    Mar 4, 2003
    537
    Florida
    Fantastic watch Jim, with an equally amazing provenance!
    Paul
  4. Donovan Martin
    Donovan Martin Registered User
    Jul 12, 2010
    439
    Pastor FBC Ropesville;OT Adjunct Professor; Photog
    Panhandle of Texas
    That is amazing. Thanks for sharing!
  5. terry hall
    terry hall Registered User
    Apr 12, 2001
    6,419
    Great item, and greater provenance... thanks for sharing...
    earlier this year 4c78535 was sold, no box or provenance though.
    Outer chapter 1/100 of a minute....
  6. 179
    179 Registered User
    Sep 16, 2008
    320
    Thanks for posting Jim. Great item with outstanding provenance. With 3 of these known now maybe another will surface in the future. Looking carefully at these, i believe the mvt.,special dial and hands were supplied to the N.O. for casing at the N.O. in the 4 piece case. Maybe Lucite rather than Plexiglass as it seems to have aged well. The protective box also appears to have been made at the N.O. by some of the construction details. Thanks again!
  7. rrstd
    rrstd Registered User
    Feb 18, 2001
    1,558
    The box and documentation that came with Jim's example certainly goes a long way in defining the story behind these devices.
    As an update, I can confirm the existance of 2 additional examples of these devices - bringing the total of known examples to 5.
    Rhett
  8. Tom McIntyre
    Tom McIntyre Technical Admin
    Staff Member Donor Sponsor NAWCC Member
    Aug 24, 2000
    77,823
    396
    146
    retired SW dev
    Boston
    A really neat artifact. It is particularly special to have the documentation from the guy who made it.
    Do these precede or follow the "NATO" 3992B's with a similar dial design for decimal minutes?
  9. burt
    burt Registered User
    Sep 5, 2008
    457
    McKees Rocks,Pa.
    Jim,
    I was very impressed with this piece, with its historical providence as well as its special purpose as a timing "check" instrument. Kudos to Hamilton also.
  10. rrstd
    Feb 18, 2001
    1,558
    The two examples below, show some of the variation from piece to piece. As can be seen, the lucite cases are slightly different in size as well as construction details.
  11. rmw
    rmw Registered User
    May 31, 2005
    111
    Tom
    The decimal watch dial you show was fairly common. I believe these watches all started life as standard Zenith or Hamilton comparing watches and had new dials put on some time after WWII. The ones I have seen were converted in England. They were used for ease of calculation. In fact so many Zeniths seem to have been converted that the conventionally dialled watch seems to be rarer than the converted version. The original dial is of much higher quality.
    RMW
  12. Dave Chaplain
    Dave Chaplain Registered User
    Rhett, is 4C20179 in a lucite case like the one on the right in post #10 already in your list of 5? :)
  13. Clint Geller
    Clint Geller Registered User
    Jul 12, 2002
    916
    I am a research physicist at a government lab
    Pittsburgh, PA
    I am puzzled by the opening post in this thread. The speed of radio waves in air is about the same as it is in vacuum, which is 300 million meters per second, or about 186,000 miles per second. So that means that a radio wave emitted from the ground and reflected from the ionosphere will be received at a point about half way around the Earth in about a tenth of a second. Changes in the time of travel of an electromagnetic wave between any two points on the Earth's surface will result from variations in the height of the ionosphere above the ground - not from radio wave interference (Maxwell's Equations are linear!), nor from Doppler shifting (relativistic Doppler shifts only affect the frequency of an electromagnetic wave, not its speed). Presumably, these variations about the mean value are a couple of orders of magnitude or so smaller than the mean value itself. So that means that the variations one is attempting to measure are on the order of a few milliseconds, or less. So how can one expect to measure variations so small accurately with a timekeeper whose escapement beats only once every 200 milliseconds? The dial of the timepiece is completely incapable of registering time intervals that small. So it seems like the tool is hopelessly mismatched for the intended purpose.
  14. grtnev
    grtnev Registered User
    Jan 18, 2009
    378
    Consulting Engineer
    Minden, Nevada
    #14 grtnev, Apr 20, 2017
    Jim,
    Very, very interesting. Thanks for sharing.
    I did note that the position of the regulator is essentially all the way toward S - which is interesting.
    Richard
  15. Jim Haney
    Sep 21, 2002
    5,036
    Decatur, TN.
    Clint,
    You would have to start with the box which states the WWV or microwave signals and come up with your own theory based on your doctorate degree.
  16. Clint Geller
    Jul 12, 2002
    916
    Pittsburgh, PA
    Well, Jim, physicists are trained to perform simple, "back-of-the-envelope" calculations to determine the orders of magnitude of the quantities involved in a scenario, to see if it is plausible, before delving into detailed theories. That's what I just did, and based on my analysis, it does not seem plausible to me that any mechanical timekeeper would be useful for measuring the minute variations in the time delay between the emitted and received radio signals between any two points on the Earth's surface.
  17. rrstd
    Feb 18, 2001
    1,558
    Dave, the recent online sale was a new example. Which puts the total I've recorded at 6.
  18. Dave Chaplain
    Hey Rhett, for the list, it looks like 4C101699 in a case that looks like the one on the right on post #10 was sold on the large auction site in May. Are there now 7, or was that one of the first 5 recorded?
    It also appears that the seller has sold two of these in the past couple of months, the other being the one I got, 4C20179 ... :O
  19. rrstd
    Feb 18, 2001
    1,558
    Dave,
    I've been wondering who might have purchased that last example.
    The most recent example makes a total of 7 I've recorded.
    Rhett
  20. Dave Chaplain
    Rhett, I wasn't the buyer (unfortunately)! I hadn't even seen it until yesterday when the buyer contacted me to discuss it some ... I must be slipping some ... :p
Similar Threads - Hamilton 4992B used Forum Date
Hamilton 4992B "Gold Tone" Case. What is it? American Pocket Watches Jul 4, 2017
Hamilton 4992B case inscription translation help American Pocket Watches Jun 9, 2017
Waltham 16A v. Hamilton 4992B American Pocket Watches Feb 18, 2017
Hamilton 4992B Case American Pocket Watches Jul 24, 2016
Hamilton 4992B American Pocket Watches Mar 9, 2015
