Hi, sorry dont have any photos to post now.
i acquired this watch with a broken staff. The watch had been dropped. The watch is in relatively good condition otherwise and case wear and lack of tool marks on movement show it has had an easy life. So i figured replace staff and set mainspring and i would have a nice watch. After repair it runs about 90 seconds fast in 24 hours, with the regulator centered on the rate scale as it should be. If I move it all the way to "slow" watch will come close to being regulated, but i know this is not the way to do it.
I carefully replaced staff no manhandling of balance wheel, balance is serial match to movement. Roller plate installed in original position to wheel etc.. The balance weights do not appear to be molested under 10X. The jeweling is good and staff endplay is good. amplitude is good sorry i do not recall the readings I got at this moment, but was over 270. The balance spring looks great, no signs of rust. it is perfectly centered and on plane no indication of reason for increased speed. the regulator pins are strait and spaced well. The only question i have about balance spring is it has a round stud that mounts under a curved plate on cock with two screws, this arrangement would allow some "wiggle' room for position of spring stud. I have tried resetting the stud after assembled while running and static and before balance cock is installed. It seems to make no difference to the performance of the watch.
one of the pallet fork banking pins appeared to have been moved and i have returned it to what i think is correct but i am having a hard time telling on this type movement with the fork sandwiched between plates. the pallets lock well and the banking pin appears to be set to the least clearance to roller.
The only other item i can think of is the new spring effecting the rate. but my experience with other watches is even of i put an old set spring back in the watch rate doesn't really change. the new spring is an alloy type.
So I think I have some understanding of how these work but I don't see why this watch didn't return to proper operation. It appears to be getting down to a weight issue on balance. There are no "timing screws" to attempt adjustment as a last resort.
Am i overlooking something? what could have caused this increased rate?
perplexed.
Joe
perplexed.
Joe
