Hamilton 12-size
Discussion in 'American Pocket Watches' started by John Arrowood, Oct 8, 2019.
  1. John Arrowood
    John Arrowood Registered User
    Dec 14, 2001
    704
    98
    Here are three Hamilton 12 size watches I have had for a few years. Left one Is 17-j, adjusted, 910, serial 1835706 with a 1919 presentation date. Middle is a 23-j 5 adjustments, no model no., serial 1766768. Third one is 17-j 914, 3 adjustments, serial 1845392, 1940 presentation date. All are in gold filled cases. And all are in the cases where the bezel is hinged at 6 and the movement is in a ring hinged at the left side of the case. What is the name for such cases and did any other maker use this style? View attachment 551482
  2. musicguy
    musicguy Moderator
    NAWCC Member Sponsor
    Jan 12, 2017
    4,862
    2,224
    New York State
    This one is a grade 920.
    They are called swing ring cases and a lot of makers used them.
    check out the wiki case type
    Rob
  3. Jim Haney
    Jim Haney Registered User
    NAWCC Member Donor
    Sep 21, 2002
    6,311
    878
    Working the farm, Garden,horses, goats, chickens,
    Decatur, TN.
    John,
    I don't recall if Hamilton had a name for them or not? We always just called them Swingring cases.
    Your 1766768 is a grade 920 and the grade was usually above the smaller winding wheel.
  4. Jerry Treiman
    Jerry Treiman Registered User
    Aug 25, 2000
    6,098
    1,105
    Geologist - California Geological Survey
    Los Angeles, CA
    Case manufacturers usually called these single-jointed cases. "Swing ring" is usually reserved for cases with a screwed bezel and the ring hinged by the pendant.
  5. John Arrowood
    Dec 14, 2001
    704
    98
    Thanks for the replies. understand the regular swing out cases where the stem is pulled out and the movement and ring containing it swing out from the top of the case after unscrewing the bezel. I have a Keystone Howard railroad in such a case. These 3 just seemed odd to me.
  6. John Arrowood
    Dec 14, 2001
    704
    98
    After reading the wiki page it appears that the cases are clam shell type.
  7. Jerry Treiman
    Aug 25, 2000
    6,098
    1,105
    Los Angeles, CA
    In my opinion and experience "clam shell" is really a rather recent and informal term (unless you can show me period literature or ads using that term). The attached image is from a 1917 Hamilton catalogue page published by Benjamin Allen & Co. (reprint). This case style is clearly called a single joint case. This term was also used by other case companies for these cases.
    viclip likes this.
  8. Kent
    Kent Registered User
    Gibbs Literary Award NAWCC Fellow NAWCC Silver Member
    Aug 26, 2000
    18,300
    1,507
    Ed Ueberall and I started using "Clamshell" (or Clam Shell) to refer to this style of case about 20-25 years ago. "Single Joint" didn't seem right due to the fact that there are clearly two hinges. Perhaps through the constant appearance of the below ad (red text in the ad is mine) and/or the use of the term in the "How To Open A Pocket Watch Case" Encyclopedia article, "Clamshell" got picked up by others.
    However, if I were to "name it" today, I agree that "Single Joint" would be the correct term to use insofar that it appears to have been the industry-wide tern for these cases. If there is a consensus of opinion posted to change the ad note and article to use the "Single Joint" term I'll be glad to do so.
    viclip likes this.
  9. musicguy
    musicguy Moderator
    Jan 12, 2017
    4,862
    2,224
    New York State
    I think it's a good idea to change it to the industry-wide term Single Joint.
    Rob
    TimeAntiquarian and viclip like this.
  10. Jerry Treiman
    Aug 25, 2000
    6,098
    1,105
    Los Angeles, CA
    I, too, would prefer to see these identified by the period terminology.
    The "single joint" ignores how the movement is retained and just refers to the single joint connecting the front and back of the watch case.
  11. Kent
    Aug 26, 2000
    18,300
    1,507
    musicguy and viclip like this.
