Hi Everyone,
First time posting something here so please correct me if I'm not doing something right.
I have the movement partially assembled but totally lost on the adjustments necessary. Manually moving the chime side and moving the minute hand to each quarter results in the same amount of revolution of the two cams (chime stop and autocorrection?) that are mounted on the same arbor. The chime cam stops at the same place after about a turn and a half. There is a wheel with a pin that I believe stops the chime. Perhaps that is what I adjust by slightly separating the plates? I'm posting pics and hope someone has worked on a movement like this one.
Thank you
Thank you
