BillnHsv
- Dec 27, 2017
- 7
- 1
- 3
- 59
- Country
Hello: I just bought a GB wall clock. The movement has P48 stamped on the back but no serial numbers. There are some things that are not original and I need advise on how to start my repairs on the case. The first thing is the board the movement is mounted to is plywood. I think the case is mahogany? So I have a piece of solid mahogany wood for the new mount. I'm hoping the cutout was made from the original but I'm not sure. If you think it is I will copy it? The mounting board is 9 1/4" wide X 2 3/4" inches deep.
There is a metal bracket mounted to the back so I'm not sure the movement is supposed to be board mounted or was mounted to the metal bracket in the back? If not for mounting the movement what is it for?
There are side mounting boards with slots which have been moved. I don't know it they are original? They have been moved so I'm not sure if it is because of the plywood base and moved to center the face?
The two side mounting block are 3 5/8 inches long X 1 7/8". Any advise would be appreciated.
