$ Gustav Becker Tallcase clock value?
clc
May 30, 2017
346
Hi.
This tallcase clock has a 1909 Gustav Becker movement. The clock runs and keeps time well.
All glass on the door are beveled.
I just don't have any idea of its value.
Can you, please , help?
Thanks,
Carlos
Reactions: Kevin W.
macaw
Jul 23, 2014
640
11
Minnesota
If the back of the clock is missing as it looks in the picture, 2-300, if it's been refinished as it also looks, then closer to the 200.00.
clc
May 30, 2017
346
Thank you guys for your input.
I have the back of the clock. I removed it to clean the whole of the inside.
I cannot tell if the cabinet was refinished
Carlos
44,320
1,354
I'm not so sure it's a Gustav. I like the looks of it though.
44,320
1,354
Thanks, clc. I'm used to the Anchor symbol on GB's. I see now that there are some years they did not use it :)
brian fisher
Jan 20, 2017
1,650
406
houston, tx
i really don't think it being a becker really adds or subtracts much value anyway. if it were a 3 weight clock, that would probably increase the value to 6-700 dollars-retail.
if you can't tell if the finish is original, it probably is. definitely redder than any i've seen, but it looks pretty good to me
Topic related ad experiment
160,917
1,395,988
82,909
Zebralord
1,099
2,788
