O
Ouchie
I have just "rescued" a Gustav Becker, oak cased, striking mantle clock (circa 1920) from a Charity Shop as a restoration project. It appears that the clock, although hardly pristine, is complete except for the suspension spring and key. I have approached one or two Clock Material Suppliers in the UK but they cannot identify the type of suspension required without a pattern and none of those on offer in the usual catalogues are suitable. The clock has a small dial on the main dial which can be altered to adjust the suspension length using a system of levers. I have no broken pieces which could be used as a pattern but it appears to require a strip attached to the adjusting levr at the top if the back plate which apparently should then pass through a split brass projection (also broken)and finally attached to the pendulum.
Broken Suspension
Back Plate The Clock
I am attaching photos which might make the problem a little clearer!!
Ouchie
Broken Suspension
Ouchie
