• Important Executive Director Announcement from the NAWCC
    The NAWCC Board of Directors is pleased to announce that Mr. Rory McEvoy has been named Executive Director of the NAWCC. Rory is an internationally renowned horological scholar and comes to the NAWCC with strong credentials that solidly align with our education, fundraising, and membership growth objectives. He has a postgraduate degree in the conservation and restoration of antique clocks from West Dean College, and throughout his career, he has had the opportunity to handle some of the world’s most important horological artifacts, including longitude timekeepers by Harrison, Kendall, and Mudge.
    Rory formerly worked as Curator of Horology at the Royal Observatory, Greenwich, where his role included day-to-day management of research and digitization projects, writing, public speaking, conservation, convening conferences, exhibition work, and development of acquisition/disposal and collection care policies. In addition, he has worked as a horological specialist at Bonhams in London, where he cataloged and handled many rare timepieces and built important relationships with collectors, buyers, and sellers. Most recently, Rory has used his talents to share his love of horology at the university level by teaching horological theory, history, and the practical repair and making of clocks and watches at Birmingham City University.
    Rory is a British citizen and currently resides in the UK. Pre-COVID-19, Rory and his wife, Kaai, visited HQ in Columbia, Pennsylvania, where they met with staff, spent time in the Museum and Library & Research Center, and toured the area. Rory and Kaai will be relocating to the area as soon as the immigration challenges and travel restrictions due to COVID-19 permit.
    Some of you may already be familiar with Rory as he is also a well-known author and lecturer. His recent publications include the book Harrison Decoded: Towards a Perfect Pendulum Clock, which he edited with Jonathan Betts, and the article “George Graham and the Orrery” in the journal Nuncius.
    Until Rory’s relocation to the United States is complete, he will be working closely with an on-boarding team assembled by the NAWCC Board of Directors to introduce him to the opportunities and challenges before us and to ensure a smooth transition. Rory will be participating in strategic and financial planning immediately, which will allow him to hit the ground running when he arrives in Columbia
    You can read more about Rory McEvoy and this exciting announcement in the upcoming March/April issue of the Watch & Clock Bulletin.
    Please join the entire Board and staff in welcoming Rory to the NAWCC community.
Gustav Becker Dilemma
TEACLOCKS
Mar 22, 2005
2,602
106
70
Santa Rosa Calif.
www.weserviceallclocks.com
I have 3 choices.
1- Replace the wheel with the 2 broken & 3 bent teeth on the left with the wheel on the right ?
2- repair the 2 missing & 3 bent teeth on the wheel on the left ?
3- Shorten the hour cannon on the Right to match the one one the left ?
I am Bushing the movement on the left.
In the tear down I found that the hour cannon teeth were bent & I tried to straighten, & thoughts 2 broke.
What would you do :???::???::???:
DSCF8001.JPG DSCF8002.JPG DSCF8003.JPG DSCF8004.JPG DSCF8005.JPG DSCF8006.JPG DSCF8007.JPG
chimeclockfan
Dec 21, 2006
4,388
350
WI
Movement with wire lift hammers is a Wewi Gong No. 16, introduced 1926 and produced up to 1932. Junghans began amalgamation with VFU/Gustav Becker when these clocks came out so the Junghans influence is apparent on the chime drum design. Your clock was most likely made between 1928-1929 going by the serial, however it was recently discovered that not all stamped serials on these movements were chronologically numbered. Plays Whittington and Westminster chimes. It was a derivative of the original VFU/Gustav Becker Westminster chime movement you have sitting alongside, changes primarily being made to chime drum and pendulum components.
I would suggest trying to repair the broken parts first, only doing transplants as last-resort when all else fails. The dual chime Beckers are very uncommon and usually turn up in Britain.
The other movement is a typical VFU/Gustav Becker with Westminster chime and was made before the Junghans amalgamation. The pendulum length in centimeters suggests a wall clock case with a wood stick pendulum.
bruce linde
ADMIN / MODERATOR
8,144
1,114
oakland, ca.
clockhappy.com
replace the teeth... there are tutorials here on the MB... if i can do it, you sure can! (and, it's actually both straightforward and kind of fun)
TEACLOCKS
Mar 22, 2005
2,602
106
70
Santa Rosa Calif.
Chime
What does VFU Stand for ?
chimeclockfan
Dec 21, 2006
4,388
350
WI
That is correct. The formal company name was Vereinigte Freiburger Uhrenfabriken inkl. vormals Gustav Becker - bit lengthy for the brand marketers who just stuck to the Gustav Becker name as it was the most recognized of the 6 companies that had formed together. From the latter half of 1926 onward it was basically under Junghans control as part of the amalgamation, gradually merging into a standardized production line that no longer included the Freiburg factory after December 1932. The later 'Gustav Becker' clocks shared more and more in common with what Junghans cranked out during the same time period.
The entire Wewi Gong setup can be seen here - for mantel clocks, it always resides in a tambour case:
Junghans put it on a diet in 1929 and the result was this dual chime version of the Junghans W200/100 movement, which sometimes bears the Becker or HAC trademark. Chime drum is the only part shared in common:
45,538
1,634
I'm assuming you acquired the second movement on it's own (no case)? I think I'd put new teeth in the broken one to keep it original, and then refurbish the second one and sell it, or find a case for it. It's a win/win situation.
Reactions: chimeclockfan
TEACLOCKS
Mar 22, 2005
2,602
106
70
Santa Rosa Calif.
Thank you all for the shove.
I repaired the tooth, the others I was able to bend back straight, not the best repair It is the motion works no power.
And Shutterbug I am always finding moves in a box somewhere.
Thank you all for the info, I didn't realize the one movement was so much older then the other ( serial number )
Can you find the one I repaired ?
45,538
1,634
Looks good! :thumb:
Latest posts
163,536
1,421,047
84,938
Naama
2,857
Aurora's 15 Ruby Jewel Movements by Greg Frauenhoff
Copyright © National Association of Watch and Clock Collectors Inc (A 501c3 non-profit corporation). All Rights Reserved.
