• Upcoming updates
Gustav Becker Clock
MikeC
Aug 14, 2005
97
Montreal
time.currangroup.net
Hi all,
I just purchased this Gustav Becker. The clock has a hinged front door and is 30 inches high, 13 inches wide, 6 1/2 inches deep. Face is 8 inches diameter. There are two small glass portholes on the sides that the movement can be seen through. It is spring driven. From what I can see it was manufactured between 1925 - 1933 in Freiburg Germany. I've searched the movement and can't find a serial number, so I used the logo to date it. I've included links to some pictures to see if anyone might be able to tell me if this is right or can tell me the exact year it was made. Also I've been referring to this clock as a "Box Regulator" is this correct?
Thanks for any help.
Mike
Clock: Click Here
Movement: Click Here
Right side: Click Here
Left side:Click Here
Logo: Click Here
Sooth
Feb 19, 2005
4,025
109
39
Cornwall, Ontario, Canada
www.angelfire.com
Your clock is indeed a Box Regulator, and was likely made between the dates you stated. Not all GB clocks have a serial number, and for what it's worth, you clock is pretty close to the same as mine, only yours has a nicer case. See my clock on my website for reference.
I hope you will clean the movement. It looks like it needs cleaning quite badly.
John Hubby
Senior Administrator Emeritus
NAWCC Star Fellow
NAWCC Life Member
Sep 7, 2000
12,295
278
The Woodlands, TX
Right on all counts for description. My data show this back plate marking (letters H and K with GB Anchor logo) was used as early as 1919 so it might be a bit older than 1925-33. There were several letter markings used during the period from 1910 to 1940 but so far I don't have enough data to make a good correlation for how they were used or in what years.
John Hubby
Joseph Bautsch
Dec 9, 2006
1,113
127
82
Atlanta, GA
Mike - If you are just getting started in clock repairing this web site will provide information on finding providers of tools and equipment as well as what is needed to get started. Go to:
http://www.ticktockrx.com/
Click on the beginning clock repairman category.
179,951
1,569,767
54,328
redepicted
911
3,090
