Gustav Becker clock
Discussion in 'Clock Repair' started by mariosthegreat, Apr 13, 2017.
  1. mariosthegreat
    mariosthegreat Registered User
    Jul 6, 2014
    158
    Hi all
    The bangs correctly until it gets to 7 to strike 8 bangs. And so on till it gets to 1 when it works correctly.
    I took our the hour hand and put it on 8 . When it got to 9 it banged 10 times.
    Pl help. It's a grand fathers clock.
  2. John Hubby
    Sep 7, 2000
    11,205
    19
    The Woodlands, TX
    My experience is that the problem is most likely the strike rack tail is not adjusted properly, allowing the gathering pallet to miss pick-up of a rack tooth at the 7:00 position. Moving the hour hand will not solve the problem as you have discovered.
    Adjustment of the part will require removal of the hands and dial, then adjustment of the rack tail to ensure that a rack tooth is picked up on every half-rotation of the gathering pallet. Note the gathering pallet has two lifting pins so each pin should pick up a rack tooth with each half rotation. I am attaching a photo of a GB grandfather weight driven time & strike movement that should be similar to yours. The parts I have described are labeled for your information.
    Note that the rack tail is not in the correct position in the photo; it should be below the snail with the position pin underneath the snail. The rack tail is adjustable at the center where it is mounted on a post, there should be a locking screw that can be loosened and then the tail moved slightly to adjust the position of the rack teeth to allow the gathering pallet to pick up one tooth on each pin. The tail is a friction fit so it may take a little force to move.
    It will be appreciated if you could post photos of your clock including a full view of the front, close-ups of the dial and back plate of the movement, and also a photo of the gong that will be mounted in the back of the case. We can accurately date your clock from the movement serial number and possibly provide a model number for the case if it has been illustrated in one of the GB sale catalogs we have available.
  3. klokwiz
    klokwiz Registered User
    Donor NAWCC Member
    Feb 4, 2009
    1,043
    WRENCH
    Annapolis, MD
    I agree completely with John's description of the likely problem. Just had one that needed just a minor adjustment to strike rack to stop mis strike on 1-4 o'clock. I would add that you verify the strike rack freely moves and lands the same each time. Also inspect the rack teeth for condition. Also that the problem is always in the same hours, before making adjustments to rack. Joe
  4. THTanner
    THTanner Registered User
    Donor NAWCC Member
    Jul 3, 2016
    961
    Carson City, Nevada
    Also check that the little pins on the gathering pallet are not bent in such a way that they don't always catch every tooth the same.
  5. mariosthegreat
    Jul 6, 2014
    158
    Many thanks. I'll post photos as required as soon as possible.
  6. mariosthegreat
    Jul 6, 2014
    158
  7. mariosthegreat
    Jul 6, 2014
    158
  8. mariosthegreat
    Jul 6, 2014
    158
  9. mariosthegreat
    Jul 6, 2014
    158
    I'll send you the number on the back plate soon.
  10. mariosthegreat
    Jul 6, 2014
    158
  11. mariosthegreat
    Jul 6, 2014
    158
    I've successfully repaired it. There were more than one problem.
    I'd like to thank you with the other friends who did share.
  12. mariosthegreat
    Jul 6, 2014
    158
    Waiting for more information on my clock, please.
  13. John Hubby
    Sep 7, 2000
    11,205
    19
    The Woodlands, TX
    Mario, thanks for the additional movement photos, those are quite helpful and I will provide a date and other information in my next post. Do you have a case for the clock? I had asked for photos of the case, also the gong so we can do a complete documentation.
  14. mariosthegreat
    Jul 6, 2014
    158
    Ok. I'll send you what you want.
    Many thanks.
  15. mariosthegreat
    Jul 6, 2014
    158
  16. mariosthegreat
    Jul 6, 2014
    158
  17. mariosthegreat
    Jul 6, 2014
    158
  18. mariosthegreat
    Jul 6, 2014
    158
  19. mariosthegreat
    Jul 6, 2014
    158
  20. shutterbug
    34,321
    Mario, you can add multiple pictures to one post. It would help to keep things more manageable on the BB ;)
  21. mariosthegreat
    Jul 6, 2014
    158
    #21 mariosthegreat, Apr 19, 2017
  22. mariosthegreat
    Jul 6, 2014
    158
    The beat of my clock isn't stable. It goes up and down. The pendulum
    Stops many many times.
    I took off the pendulum still the problem of the beat.
    Pl. Help.
  23. mariosthegreat
    Jul 6, 2014
    158
    Still waiting for your information on the clock please.
  24. wow
    wow Registered User
    Jun 24, 2008
    2,126
    Retired Music Minister
    Pineville, La. (central La.)
    Re: Gustave Becker clock
    Is this the same clock you already posted about, or a different one. We need more details.
  25. Kevin W.
    Kevin W. Registered User
    20,162
    Has it been serviced recently.
  26. bangster
    bangster Super Moderator
    16,290
    20
  27. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    What is it you wait for? We have asked for pictures
    of the from of your movement. We've not seen these yet.
  28. John Hubby
    Sep 7, 2000
    11,205
    19
    The Woodlands, TX
    Mario, thanks for the additional photos. However, please note that you can post up to 10 photos in each post, which makes it much easier for us to see what you are presenting. If you need assistance for this there is an instruction thread at the top of each forum how to use our photo posting system.
    I was hoping the photo of the back of your movement would be clear enough to see the serial number, however I presume the actual number is what was written on a paper that you posted. Based on that serial number, your movement was made in the January-March quarter of 1904. I notice the pendulum length stamp (P 65.5) on the back of the movement shows it is 65.5 cm long, which indicates this movement was most likely made to be mounted in a large Vienna regulator case instead of a medium size grandfather case.
    It appears that the case for your clock was made by a craftsman or hobbyist (not by the GB factory) some time later than the movement was made. It is a traditional design and has a generally pleasing appearance, however there are not any designs like this one in any of the GB sale catalogs available. There are a number of indications of hand-made assembly and finish; for example the mounting of the movement support bracket is on a raised plank of modern grooved wood and not directly on the back board of the case. The dial also appears to be from a later period than the movement, likely by 20-30 years. However, the hands are correct and fit the dial.
  29. mariosthegreat
    Jul 6, 2014
    158
    Yes it is.
    - - - Updated - - -
    Yes
  30. wow
    wow Registered User
    Jun 24, 2008
    2,126
    Mario, your clock has a beat adjuster at the bottom of the crutch which is adjusted almost as far as it will go to one side in your photo. I would adjust it back to the middle of the crutch and then set the beat by holding the pallets with one hand and gradually moving the crutch, allowing it to slip on the arbor, until the clock is in beat. When it is in beat, you will hear the tick at approximately the same distance from the center of the pendulum swing on the left side and the right side. Once you reach that point, it is easy to adjust the beat with that adjuster on the bottom of the crutch. It should keep running once you get it perfectly in beat.
  31. shutterbug
    34,321
    I have merged these threads, Mario. It's just too convoluted to have multiple posts about the same clock!
Similar Threads - Gustav Becker clock Forum Date
Gustav Becker clock Clock Repair Apr 24, 2017
How do i open a sealed spring barrel of a Gustav Becker clock? Clock Repair Mar 16, 2017
Gustav Becker chain driven clock - strike problem Clock Repair Nov 6, 2016
Gustav Becker wall clock mainspring problem Clock Repair Oct 21, 2016
Gustav Becker wall clock issue Clock Repair Apr 15, 2016
