I have a Gustav Becker, 3 barrel, Westminster chime clock that needs an overhaul. It's still in the case, so I can't provide pictures, but for identification, on the back appears P18, Medaille d'or, S, 2244929, and G.B. Freiburg in Schl[esien]. I have never worked on a Gustav Becker clock, and am looking for a manual that has info mainly on assembly, reassembly, etc. I have Conover's "German Clocks," but that addresses mainly the chime movement. Is there any other reference material available about Gustav Becker clocks? Also, I'm sure the clock will need bushings and would like to know if the same Bergeon bushings I use for American clocks are appropriate for this clock, and if not, what should I use? Thank you very much for any suggestions.
Paul
Paul
