Gustav Becker clearance
CameraGuy32
Apr 12, 2019
130
41
Just took in (2) Gustov Becker clocks produced around 1885 for service. Nice thick plates with no wear. Customer picked them up at an estate sale for $75.00 - for both.
I've noticed that When I hang them to work on, if they are plumb and straight, the pendulums rub on the back and gong rod. I have to pull the top out almost 1 inch to get clearance for the pendulum to swing. Is this a regular thing with these clocks?
Steve
13,738
1,415
The movement might be slid in to far. If not, might be the wrong pendulum. The pendulum doesn't look right on the clock to the left.
Where are you placing the level. Front glass or backboard would be good.
CameraGuy32
Apr 12, 2019
130
41
The bracket that holds the movement and pendulum are mounted to the backboard. Pin on the leader fits into the pendulum. There is no adjustment. I've never seen anything like this.
JimmyOz
Feb 21, 2008
802
166
65
Gold Coast Qld
It could be the crutch is pushing the pendulum back into the case a bit, try to get it more parellel with the back plate of the movement.
wow
Jun 24, 2008
5,046
500
75
Pineville, La. (central La.)
There is no leader on Vienna weight clocks. The pendulum is mounted on the back of the case and the crutch pin goes in the slot on the pendulum. So yours is right. The crutch on yours is bent out away from the back of the movement and should hang parallel to the back plate like Jimmy said. Then the pendulum will not rub.most Vienna pendulums are just a wooden rod like the one on the right. That brass rack has been added. Not necessary.
svenedin
Jan 28, 2010
1,192
207
Surrey
Your customer did very well. I know the price of clocks has gone down but $75 the pair? This is getting ridiculous!
CameraGuy32
Apr 12, 2019
130
41
There is no leader on Vienna weight clocks. The pendulum is mounted on the back of the case and the crutch pin goes in the slot on the pendulum. So yours is right. The crutch on yours is bent out away from the back of the movement and should hand parallel to the back plate like Jimmy said. Then the pendulum will not rub.most Vienna pendulums are just a sodden rod like the one on the right. That brass rack has been added. Not necessary.
Interesting. Thanks, Will. I'll try to slightly bring the pin back to parallel.
165,376
1,439,392
86,181
Kevsun
2,873
