Help Gustav Becker - BPH?
Reuven Gruber
Jun 2, 2020
34
79
Does anyone know the BPH for this movement?
The approximate 1637260873974.jpg 1637260873989.jpg WhatsApp Image 2021-11-16 at 08.03.58.jpeg WhatsApp Image 2021-11-16 at 08.03.59 (1).jpeg age of the movement would be helpful
16,847
2,824
Just check the hands every few hours (or days) and move the pendulum up for faster, down for slower. It's as simple as that. :)
Short pendulum clocks can take several winding cycles to regulate to the best of their ability.
Steven Thornberry
User Administrator
Jan 15, 2004
24,701
2,080
Here and there
This is actually a Junghans movement sold with the Gustav Becker brand after Junghans took over the Becker operations. The movement date is December 1935 (35 12).
48,754
2,627
If your beat setter has a counting application, just mark a starting point for the minute hand and let the machine count while the hand moves around the dial. About three times is most accurate. Then stop the counting when the minute hand touches the starting point again. Divide the count by the number of rotations and you have an accurate BPH count needed for the clock to keep time. Any chiming or striking needs to be disabled during the count process.
Reuven Gruber
Jun 2, 2020
34
79
Thanks for the help. I now have the date of manufacture and a way forward to get the BPH
16,847
2,824
Well, you will need to count the teeth in the time train to get an actual number.
Or, just rate in in the usual manner and save yourself a lot of trouble, time, and possible mistakes. :)
Reactions: T.Cu
48,754
2,627
Not if you have a beat counter Willie. My method above will give a very accurate BPH even without a pendulum (if it will run that way). Actually not my method - came in the instructions for my unit.
But I usually use your method of trial and error in the shop, and use the machine in the field ;)
175,192
1,532,241
52,610
manus2eire
1,063
2,972
