Hello, I’ve just bought this Vienna Regulator ($80) a few days ago. It has three weights. The first thing that I noticed was it's lack of carvings. Is that normal? I decided to post a thread here instead the Gustav Becker forum because of its issues. Then, that beat scale looks odd for this type of clock. I took it off and seen three holes. The scale is mounted with two and one screw going diagonal into the case (taper pins for some accessories are missing).
I cleaned some of the rust off:
The case has a hole in the middle and the levels are missing which is strange. Now the case is not level on the wall.
The movement:
As shown, the movement number is 615531 p27. Some unusual things I noticed was the plate that needed to be pressed in order to release the movement. Nice feature! The cat gut has gone bad but should be replaceable. During testing, i noticed this is only petite Sonnerie? Strange.
The rod gongs:
The rods are shorter than i expected, unlike some stuff I saw on youtube. chimeclockfan for identification!
The rest of the clock:
One thing I am really concerned about is this:
There are a bunch of holes that i hope did not house a different movement.
Last thing is that I don't know which weight is for which train.
Here is a list of points for (hopefully) easier navigation(first time using a computer to do a thread).
Any help/advice or information highly appreciated. Thanks!
The movement:
The rod gongs:
- Gustav Becker clock with the serial number "615531 p27".
- Case is missing levels and case has a (repro?) beat scale.
- Movement cat gut has gone bad.
- Clock has two chime rods that are short.
- Maybe petite sonnerie striking sequence.
- Has a "push to release" system for movement removal.
- Case is not level because it "rocks" side-to-side against the wall.
- Case does not have carvings.
- Case has "patched; filled" holes that could have been for a different movement.
- Weights are quite heavy.
