Whenever you install a coarse threaded screw either into wood, sheet metal, plastic, or what have you; to prevent stripping out the hole, always turn the screw in reverse, like you're taking it out, till you feel it rise a little, then drops into place in the threads, then go ahead and tighten it down. This keeps you from cutting new threads into the material and eventually eating out the hole to where there is nothing for the threads to grab onto. It is one of the first things I learned years ago as a technician, and it still works for today. There is nothing more frustrating than trying to put a movement back into a case and have the threads of the mounting screws barely catch the wood, or not at all. Make it a habit, you won't be sorry...............doc
Most visitors online was 1660 , on 12 Dec 2020
