Gruen 335 keyless work
Discussion in 'Watch Repair' started by Roy Horrorlogic, Oct 12, 2018.
  1. Roy Horrorlogic
    Roy Horrorlogic Registered User
    Mar 7, 2017
    231
    27
    I have had this watch in partially dis-assembled form for years. I've just cleaned and relubricated and the movement runs very well. However even after I changed the clutch spring for a slightly weaker equivalent the clutch doesn't engage the intermediate wheel in the setting position. The Ranfft pic is taken in the winding position and is of modest resolution so I'm unable to make a comparison of relative clutch and lever wear - I've seen much worse still functioning. I'd appreciate an informed opinion. I'm guessing that replacement parts for this movement are all but unobtainable.
    And on that, I believe this is a US-built movement? I have other Gruens with AS based movements but I'm assuming also that there is no AS equivalent to the 335 for spares donation? Snap below.
    Roy
  2. karlmansson
    karlmansson Registered User
    Apr 20, 2013
    2,324
    45
    Doctor
    Linköping, Sweden
    Wow, some pretty ugly stuff going on there... The tooth repair on the hour transmission Wheel is something else.
    The Power of the spring shouldn't matter in this case. There are hard Contacts all through the setting lever to the yoke and the clutch Wheel. It looks like the pivoting distance of the acting Surface of the setting lever is too short. Are you sure that it's an original part? The wear around it suggests otherwise. I've seem botch jobs where someone had transplanted a setting lever that was "Close enough" that did some real damage.
    Look up some Pictures of the proper part and compare both setting lever and yoke. And I would also recommend getting rid of the rust on those parts, in particular on working Surfaces.
    Best regards
    Karl
    Roy Horrorlogic likes this.
  3. Roy Horrorlogic
    Mar 7, 2017
    231
    27
    Thanks Karl
    yes that tooth is "interesting". I've found that tooth replacement generally is interesting. Usually runs out at about £2500 for one human tooth.
    I have no idea whether these parts have been replaced however the images on Ranfft, as far as it's possible to tell, look pretty identical to me. Do you know
    As for the rust, I thought I'd try to get the watch to set first. Not a lot of point in cleaning the rust off if the watch is not recoverable.
    All of which is academic if replacement parts cannot be obtained. I wish I had the tools and skills required to manufacture them.
    Here's a rough comparison with the only decent image I can find, roughly resized etc but not taken perpendicularly.
  4. Roy Horrorlogic
    Mar 7, 2017
    231
    27
    sorry, duplicate post.
  5. Chris Radek
    Chris Radek Registered User
    Apr 13, 2014
    251
    53
    Watchmaker (now accepting new customers)
    Lincoln, NE, USA
    Roy I agree with you that your keyless parts all look like the ones in the other photo, and if you've investigated the clutch lever's hole and post for wear, and the set lever screw and its hole, and all the parts for ill-advised filing marks, I think they may be fine. (Usually when someone mistakenly thinks metal swells with age, they are sloppy enough at filing to leave good evidence of their misdeeds...) The clutch is a little worn but I don't think a new one would fix your troubles. I think you need to expand your problem search. Clearly the minute wheel has been damaged and repaired, but also I notice that its depthing with the cannon pinion is way too loose, barely meshing at all, but the depthing with the intermediate wheel is too tight, and maybe it even binds. What is going on there? Could someone have replaced the minute wheel with a badly fitting part, and then moved the intermediate wheel toward it, causing both problems? Or maybe it's just the intermediate wheel's post that is worn, allowing it to be pushed out of the way of the clutch. Something is weird here and I think you just haven't looked at all the parts with an open mind (or maybe a sinister mind considering what evil may have been done beforehand!) to see the full story yet.
    karlmansson and Roy Horrorlogic like this.
  6. Roy Horrorlogic
    Mar 7, 2017
    231
    27
    Thanks Chris
    Yes, that makes a lot of sense. The minute wheel post actually detached itself and I refitted it. But I'll take a closer look at it as soon as I can and post my conclusions - if any.
  7. karlmansson
    Apr 20, 2013
    2,324
    45
    Doctor
    Linköping, Sweden
    Chris, I agree with the depthing! Didn’t see that at first but that’s weird. Is there wear on the intermediate wheel post, Roy? That could be the answer to your whole problem. Maybe someone made a bushing for that post that got lost in cleaning?
    Best regards
    Karl
  8. Roy Horrorlogic
    Mar 7, 2017
    231
    27
    Just got around to taking another look at this. As far as I can see there's no wear that would account for such a big misalignment. Here are some horrible hand held macros that show better detail. Is it possible that the stem is "almost but not quite"? I have bought another incomplete movement (plus four others that I don't need) whose KW looks very clean. Good money after bad?
  9. karlmansson
    Apr 20, 2013
    2,324
    45
    Doctor
    Linköping, Sweden
    Looking at it from this angle it really looks like the teeth of the clutch wheel are worn pretty square off. A lot of small errors from wear that add up to the problem your are encountering I think.
  10. Roy Horrorlogic
    Mar 7, 2017
    231
    27
    Some time later...
    yes, the small accumulated errors seem to have been the cause. I bought a partial movement in clean condition from USA and swapped the entire KW and stem. Problem solved. Of course I now have another four Gruen movements in rough condition that I don't really need and I'm about $50 out of pocket but...
    The dial has four (synthetic?) rubies and both it and the case are in extremely nice condition. All I lack are a set of hands. Ranfft has these at 1.22; 0.66; 0.16. I wonder what the chances are of finding a correct set of gilt hands for it? I'm not fond of fitting hands to these these bombé dials. Anyone out there in the US of A know a source?
    I'll add some snaps of the completed watch if and when I complete it but my thanks for the help and suggestions which kept me going on this one.
    Roy
  11. Roy Horrorlogic
    Mar 7, 2017
    231
    27
    I think I've found a source. Scotchwatch appear to have original hands available.
  12. Roy Horrorlogic
    Mar 7, 2017
    231
    27
    This one's finally back together and running pretty well. Getting the hands here from the USA cost me $61 all up. Crazy. I'm not sure what the original crown would have been like... I suppose I'll have to search and probably overpay for one. I reckon those are real, if likely synthetic, rubies. Odd to think that this was originally sold as a man's watch. Here are a couple of nasty hand held snaps.
    Roy
  13. Roy Horrorlogic
    Mar 7, 2017
    231
    27
    I'm trying to work out if this Gruen has a model name. The style number is 709 but that's as far as I've got. Gruen seem to have created a veritable labrynth with their various designations. I believe that the movement sn dates to 1948 and the style number to 1950 - which seem to match.
    Barney Green likes this.
