Groaner wood works weights
Discussion in 'Wood Movement Clocks' started by sportmodel1442004, Jul 10, 2017.
  1. sportmodel1442004
    sportmodel1442004 Registered User
    Nov 14, 2016
    13
    Hi guys,
    I have recently acquired a Chauncey Boardman column and splat clock. The clock is missing the weights. What are the correct weights for these clocks? I will post pics as soon as I get the clock. Thanks as always! You guys rock!
  2. gleber
    gleber Registered User
    Jun 15, 2015
    774
    Downingtown, Pennsylvania USA
    Here are my groaner weights. I believe they are 5.6 pounds for the strike and 4.6 pounds for the time. I just got the clock, so I haven't weighed them yet, but I researched the weights and they feel like those numbers are about right.
    Timesavers has a 4 lb rectangular "groaner" weight.
    Tom
  3. sportmodel1442004
    Nov 14, 2016
    13
    Thanks Tom. I will check them out!
Similar Threads - Groaner wood works Forum Date
Really a groaner. Wood Movement Clocks Oct 21, 2017
Case construction detail on groaner Wood Movement Clocks Aug 19, 2017
Chauncey Boardman groaner issue Wood Movement Clocks Jul 27, 2017
Chauncy Boardman Groaner Spring Clutch Repair Wood Movement Clocks Dec 1, 2016
wood works groaner question Wood Movement Clocks Nov 30, 2014
