GRIVOLAS PENDULUM
Discussion in '400-Day & Atmos' started by jkfabulos, Jan 26, 2019.
  1. jkfabulos
    jkfabulos Registered User
    Aug 21, 2001
    935
    60
    I am restoring a Grivolas pendulum.
    It has lead weights attached to the base with screws which I assume are for the course speed adjustment and the fine adjustment threaded unit with small brass weights. My question is are these small rectangular brass weights correct?
  2. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    3,658
    142
    Aerospace Engineer (Ret.)
    San Antonio, TX
  3. jkfabulos
    Aug 21, 2001
    935
    60
    Thanks Kurt.
    That answers the question. The parts are correct.
    However, the blocks should possibly be stacked not spaced which would more closely equal the thicker weights shown on this example,
    This would mean moving more mass with each adjustment and would necessarily cause very fine adjustments to be more difficult.
    I will try it both ways and see what works the best.
    Jim
  4. KurtinSA
    Nov 24, 2014
    3,658
    142
    San Antonio, TX
    On those small weights on either side, I would not jamb them together but rather have a slight space between them. If they're too tight, the screw could bind as it tries to turn evenly in both of the weights. Whether they're located close or far apart might not make much difference. The center of gravity of the two weights is likely what contributes to the change in the inertia...at least that seems the case to me at first glance. I'm not about to compute the moment of inertia of each small piece and combine them and then compare that to two weights right next to each other! Maybe your testing will shed some light!!
    Kurt
  5. John Hubby
    John Hubby Senior Administrator Emeritus
    Sep 7, 2000
    12,278
    219
    The Woodlands, TX
    #5 John Hubby, Jan 26, 2019
    The weights are correct. Most of these I take apart have the two weights on each end of the adjusting rod set very close to each other but not touching, I think for the reason Kurt surmised.
    I notice the pendulum serial number is 2017. Reviewing my database there is a German Grivolas with a JUF movement and JUF disc pendulum that has this same serial number, which was assigned by Grivolas as a separate and independent series of numbers for their German movement clocks. However, if you have a clock with a Grivolas movement that goes with the pendulum it's not in my database, would like to add if you could forward me the photos or post them here.
  6. jkfabulos
    Aug 21, 2001
    935
    60
    I am restoring the clock and will post photos when completed. The movement is also #2017.
