Hello!
I know this to be a matter of preference and I've heard good arguments for each. I'm just now thinking that I've not yet understood how to do both in a way well enough to be able to choose one over the other.
I started out turning with a small watchmakers lathe and hand held graver and had some success. I started out using the graver "right side up", that is with the ground diamond of the graver facing the work. Had some issues with gravers dulling, not getting any real chip formation and pressure polishing. So I tried switching to having the ground diamond facing away from the work and using one of the flat sides of the graver as the cutting edge. This allowed me to get better cutting action, especially in brass, but also resulted in the work climbing on top of the graver and bending/snapping more often than before.
Lately I've done far more turning on a larger toolmakers lathe with carriage and cross slide. Coming from that perspective and looking at tool geometries I'm reassessing this again. Using the first technique, with the diamond facing the work, I would almost need to angle the graver so that the handle is positioned below the work if I'm to keep the T-rest anywhere close to the work and to keep a 7 degree negative rake as is best for steels. It also means that I would more likely than not have to have a pretty substantial gap between the work and the T-rest with the rest below the work as most T'rest designs that I've seen look much like wood turning lathe rests where the tools are actually held inverted. They slope towards the work.
The risk of slipping off the work when turning and the often times resulting negative cutter rake (which in retrospect probably explains quite a lot of my issues with dulling and pressure polishing) makes my current use of this method less than ideal.
On the other hand, the inverted method also calls for a gap between work and T-rest; the height of the graver blank that is.This creates a pivot point in an awkward place that makes the cutting edge difficult to keep on the center line of the work, leading to the aforementioned tendency for the work to climb onto the cutter. The cutting geometry is however much easier to adapt to the material being turned. Neutral for brass and 7 deg pos. for steel.
My thoughts are that there are three main things to consider:
1. The graver needs to be ground so that the "diamond" isn't symmetrical to be used in the "face up" fashion, but with a thinner leading edge towards the work, effectively creating a more negative rake from the start.
2. The intended way of turning steel this way IS actually to use a negative cutting geometry and I just don't have the technique down.
3. There is something here that I'm missing or misunderstanding completely...
Help?
Regards
Karl
Help?
Regards
Karl
