Graphite Powder
Discussion in '400-Day & Atmos' started by Bod, Oct 12, 2019.
  1. Bod
    Bod Registered User
    Mar 10, 2019
    44
    Could this be used for main springs, in place of oil?
    I'm thinking of the powder used for lubricating door locks, as it would not dry out, but would need to be evenly spread to start with, and would keep the coils apart, preventing suction.
    Bod
  2. Wayne A
    Wayne A Registered User
    Sep 24, 2019
    428
    62
    Retired, process controll systems
    I'm using graphite with synthetic 5-20 Pennzoil Platinum motor oil mixed into a thick slurry, so far its working great. Since the springs are raw steel you need some small amount of oil to prevent rust. No sticksion vacuum with this graphite slurry mix. Powdered teflon would probably give similar results but have not tried it, anything to prevent the coils from full flat contact should stop the sticksion vacuum.
    Ideas for reducing friction
  3. Kevin W.
    Kevin W. Registered User
    22,631
    397
    Graphite makes a real mess, there are much better lubes for main springs.
  4. Bruce Alexander
    Sponsor NAWCC Brass Member
    Feb 22, 2010
    7,123
    690
    I'm "lifting" a quote from John Hubby on this topic
    Here's the source thread: Mobil 1â„¢ 15W-50 full synthetic oil at Walmart. $6.95/qt.
    I know that some folks here add powered Teflon to various lubricants. It tends to settle out so you have to get it back into suspension before you apply it.
    Like Kevin, I don't think I would use Graphite. At least not by itself. Wayne apparently has good results using it with an oil carrier. A good, high viscosity Synthetic Motor Oil should work fine. You can try to improve upon it with graphite or Teflon additives but the question becomes, "How much is enough?".
    Good luck,
    Bruce
  5. Wayne A
    Sep 24, 2019
    428
    62
    For sure it can be messy. Best way I've found to get the graphite power out the tubes is just tap it against a mixing cup and let if fall out with at most a very slow squeeze. Otherwise you can make a graphite cloud! Then drop the oil into the graphite, mix. Handle spring with gloves after applying the mix.
    Worked in an oil refinery and the pipe fitters used a product called "never seez" to prevent pipes and bolts from fusing together even at high temperature. Never seez is grease full of graphite and other finely ground metals depending on the type. The stuff works. Anyway the saying goes if you get it on you don't bother trying to rub it off, the spot only gets bigger. Takes abrasive soap to get it off, lol.
    Another use I have for graphite is to mix graphite and silicone oil to lube model helicopter tail rotor drive belts preventing static sparks. The helicopter tail boom is a picture of a Van de Graaff generator.
  6. Bod
    Bod Registered User
    Mar 10, 2019
    44
    Thanks for all the replies.
    I think I will go with Wayne's method of mixing it with oil, trying to get the best of both worlds.
    I have JUF 400 day clock which is showing a tendency to spring bind, regulated to good time, then a few weeks later running slow, speeding up again...
    Time to get the winder out.
    Reading the links supplied, it looks as if I've opened a discussion, very similar to asking how to sharpen a chisel on a woodwork forum!
    Bod
    Wayne A likes this.
  7. shutterbug
    44,059
    1,323
    Let us know how it goes. That stuff is nearly impossible to get off once you use it, so be very sure you want to go that route.
  8. Wayne A
    Sep 24, 2019
    428
    62
    This is what the graphite mix I made looks like painted on a spring can before I pressed the lid on. On non porous surfaces it wipes off fairly easily.
  9. Bod
    Bod Registered User
    Mar 10, 2019
    44
    I've just been given some more advice regarding Graphite powder..................Don't sneeze....
    Bod
  10. Wayne A
    Sep 24, 2019
    428
    62
    Solid advice, and when I have dry powder in a mixing cup I hold my breath until I add the oil!
