I recently acquired a Long Case/Grandfather clock from a chap who was moving to a smaller house where it wouldn't fit. It used to be in his grandfather's office but hadn't been running for some years. The movement was in reasonable shape and after a good clean, de-tangling a weight cord from the barrel arbour and a bit of blacksmithing on a hand it's ticking away quite nicely. The case is a different story although, since I got it for free, I can't complain too much. Inside, it's absolutly filthy. I washed a layer of dark grime out of the top section, possibly soot from an open fire. It looks good outwardly but I get the feeling it's been put together, or repaired, on the cheap. Some of the wood seems very roughly cut and there are stray nails sticking out here and there. The roof of the top section has several cracks. I may remove it at some point for some renovation.
The dial looks, to my untrained eye, somewhat older than the rest of the clock and that pointer below centre isn't attached to any part of the movement so I'm wondering if it may be a 'Frankenclock', put together from miscellaneous stray parts.
The dial is enamel but the numbers seem to be painted on. I'm wondering about re-touching the numbers, especially the thin lines on the 'X's and 'V's but I don't know what sort of paint/ink would be used.
Any comments/advice welcome.
