Hello all.
My Grandfather has a Grandfather Clock that he's owned for over 50 years, it's likely much older than that. It's an eight day clock. One gut line snapped a while back so it hasn't been running but we've decided to tackle the job and get it going again.
I replaced the gut line on the right (heaviest weight side), and got it ticking. Amazingly, despite not working for so many years, we're chuffed that it's keeping perfect time!
Now, the only issue is the chime. It's a bell and hammer that should chime on the hour, every hour only. For the first three hours it chimed spot on. Then it stopped. The clock still ticked on perfectly. But now every hour, you hear the faint noise of some mechanism trigger but it's not getting the hammer to strike.
With the hood off and a peek inside, I gently poked a piece that looks like a blade from an old fashioned razor, (sorry, I don't have thy faintest idea what it's called, it's circled in one picture), which would then spin quickly and the hammer would strike the bell for the correct number.
After this it seemed to chime the next hour or so, but then once again, it fell silent.
Does anyone have a tips of what may be the problem or anything we should look into to try and get it chiming away?
My (very inexperienced) thoughts are;
- I've only changed the gut line on one side (new line on the right is synthetic, old lone on the left appears to be natutal that does need replacing in the near future), could this be preventing the clock from getting enough momentum to chime? (As you can see, it was certainly dusty! So I don't doubt this is something we should do, but is it the reason for the problem we're having?)
- is it just a case of the insides being a bit dusty and in need of a bit of greasing up?
- or something that a novice like me won't be able to fix?
We're in the UK, and stuck in isolation still as my Grandfather is shielding due to the pandemic and a recent diagnosis. He's very pleased it's going and keeping perfect time, but I've been defeated by the chimes! So if I could get this going again I know he'd been delighted.
Any help, tips and tricks you can offer would be highly appreciated.
Thanks in advance!
Thanks in advance!
