Grandfather Clock Chimes 2 minutes ahead
Just in Time Clocks
Sep 17, 2019
68
50
Ohio
I have a grandfather clock movement that I took out and cleaned and oiled. When I put it back together it chimes 2 minutes past the hour and half hour. The minute hand does not have a the bushing in it to move it is a fixed hand. No adjustment possible on the hand.
Any ideas it is a 2nweight cable driven
Simon Holt
Mar 21, 2017
1,048
226
Shaftesbury, UK
Have you tried turning the minute hand over?
Simon
Reactions: disciple_dan
49,130
2,775
Most GF clocks have adjustable hands. The collet in the center of the minute hand should move a little if you put something like the tang of a file into the hole and turn the hand in the way it needs to go. Put pressure near the base, not the end.
Mike Mall
Oct 27, 2021
435
145
I read that if you use the adjust not on the pendulum to slow the clock down it will work..
Us that true
No - then it will just chime even later after the hour. But if you move the nut up it will chime sooner. :)
But the hand position - relative to the chimes - won't change.
Something has changed, pictures needed to even guess.
Mike Phelan
Dec 17, 2003
10,981
379
West Yorkshire, England
Did it only do this after you overhauled it?
Otherwise, maybe someone has filed the end of the warning lever and shortened it?
17,512
3,218
On some clocks there is a gear mesh involved.
Everyone is just guessing so far. :rolleyes:
177,626
1,556,821
53,634
Mikel Edd
909
3,058
Watch Inspectors by Kent
