Mechanical WW Gorgeous Elgin wrist watch needs repair. HELP
Discussion in 'Watch Repair' started by maxbernat, Apr 11, 2017.
  1. maxbernat
    maxbernat Registered User
    Apr 10, 2015
    10
    Good morning all, I have a gorgeous little Elgin wrist watch that needs repair. I've never seen one like this. I'm not a watch expert, but I have only found pocket watches by Elgin from this era. So far, three repair shops have passed on repairing it. Can anyone recommend one that can handle this? Pics attached. Thx. Kent Reichert[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  2. MrRoundel
    MrRoundel Registered User
    Dec 28, 2010
    854
    So. Cal., USA
    Any watchmaker would at least quote you a price for servicing the watch. I can't tell the condition of the bushings, but if they're in decent shape, the watch may be worth repairing. Of course a lot depends on how much you have into the watch, and you're willing to put into repairing it. If it just needs a clean, oil, and adjust (COA), you might get by for $80-120. If it needs more, the prices start to add up quickly.
    In looking at your images, I'm not seeing hairspring on the balance. I see the stud, but don't see it passing through the regulator. If it's missing the hairspring, or it's mangled, that may be why shops are sending you away. If this is the case, you might have to keep your eye out for a donor movement (shouldn't be hard to find) to get the hairspring and second-hand from. It's a nice-looking trench-watch. Good luck with getting it repaired. Cheers.
  3. musicguy
    musicguy Registered User
    Jan 12, 2017
    1,056
    19
    New York State
    #3 musicguy, Apr 11, 2017
  4. Accutronica
    Accutronica Registered User
    Nov 21, 2016
    553
    disabled
    Texas
    I'm surprised that none of those repair shops had the parts to fix your watch with. Or they just don't think the watch is worth it. But I don't see why they would care if you're willing to pay for it.
    Robert
  5. Smudgy
    Smudgy Registered User
    May 20, 2003
    2,816
    Most places that people notice to bring their watches to are jewelers, not watchmakers. Even a lot of the places that advertise watch repair send out actual watch work. mostly just doing battery replacement in-house.
    Check the Business Directory for watch repair people and hopefully you can find one in your area. Depending on where you are you may find that you need to use the postal service.
  6. Rob P.
    Rob P. Registered User
    Dec 19, 2011
    1,524
    California
    #6 Rob P., Apr 11, 2017
    The Hairspring is there. Save the pic and then open it in your image program and zoom in. It's there. It's probably wrong or mangled though as it doesn't go through the regulator pins. Nor does it look shaped correctly to do that anyway.
    Could be a simple repair and service. Or, it could require a new donor movement and a service on it. Depending on what the OP wants to spend, it's either worth the cost or not.
    I think it's a 6s and not a 0s movement. I didn't bother to check the serial # though. Dial is nice, hands need reblued and the case looks undented. But, for some reason the pics show the back and bezel to be yellow gold and the center to be rose gold. Plus there's a lot of lead solder repair that needs cleaned up. A correct/full restoration might push the price envelope over what it's worth unless there's sentimental value in there somplace.
    T'were me and I had an attachment to it, I'd be looking for a high jewel count donor in good shape and having the case repairs checked and corrected by an expert and seeing about maybe having the case parts replated for color match.
  7. 18k BPH
    18k BPH Registered User
    Aug 18, 2016
    29
  8. Robert Gift
    Robert Gift Registered User
    Nov 12, 2012
    184
    Tree service "Branch Manager". Medical courier
    Denver, Colorado
    Re: "Run Quantity" ?
    Thank you, BPH, for that information.
    What does "Run Quantity" mean?
    Why does that differ from Total Production?
    Is Railroad Grade a more accurate watch?
    Are jewels always an odd number?
    Thank you.
    Robert
  9. Rob P.
    Dec 19, 2011
    1,524
    California
    They made the watches in batches consisting of a single particular grade. How big those batches is the run quantity. In your case, your watch is 1 of an 8000 movement batch.
    Total production is the total number of watches ever produced by the factory in that grade/size. Your watch is 1 of 8000 out of a total of 315000.
    Railroad grade is a slang term meaning accepted for use on the railroad as a timepiece. It was reserved for only specific grades of watches that were built to specific standards to help ensure accuracy.
    Yes, jewels are usually odd numbers. The roller jewel has no counterpart. Staffs and arbors have pivots on either end and can be jeweled on both ends, but the roller jewel is ALWAYS singular. There could be an exception where the roller jewel is not a jewel or the movement could have a strange setup in pivot jewels leaving one end of a staff/arbor unjeweled and also have an odd number of staffs/arbors. I don't know of any movements with this setup, but it is theoretically possible.
  10. Skutt50
    Skutt50 Registered User
    Mar 14, 2008
    2,898
    Gothenburg
    I have serviced some Swiss movements with an even number of jewels, often 16. These movements have a roller jewel but the even number comes from one additional jewel in the center wheel bridge. (They left the main plate unjeweled in the center.)
Similar Threads - Gorgeous Elgin wrist Forum Date
ELGIN WATCH Watch Repair Nov 1, 2017
GM Wheeler Elgin 18S 1890 Watch Repair Oct 22, 2017
American PW Elgin filled case Watch Repair Oct 3, 2017
Elgin Hulburd Parts Watch Repair Oct 2, 2017
Hamilton Otis Reverso Wrist Watch Case Watch Repair Sep 25, 2017
