I have an hermle 0451 which I rebuilt recently. It needed a lot of work as it was very worn. 10 hours later I finally completed it! I always find it strange when for example you can have two brand new 0451’s and one chimes at a much faster rate than the other.
The used movement that I’ve just rebuilt chimes the quarters relatively slow. Naturally I thought that i had messed up with the rebuild . However I decided to test the movement out by exchanging the heavy lead filled weight with a iron filled weight and the lighter weight still operated 1x4, 2x4, 3x4, 4x4 albeit chiming very slow. I therefore have two questions;
Based on the new movements why do the rate of chimes differ so much and finally ,
if a much lighter weight can operate the chimes is that a good sign that the rebuild I did has been successfully done?
Thanks as always
Thanks as always
