Glue in bushings?
Discussion in 'Clock Repair' started by D.th.munroe, Apr 6, 2019.
  1. D.th.munroe
    D.th.munroe Registered User
    Feb 15, 2018
    494
    187
    Full time clock and watchmaker
    BC Canada
    I've seen alot of these over the last few years in many different clocks.
    I guess it sortof worked and didn't do as much damage as screw in or screw on ones.
    Dan.
    20181021_174856.jpg 20181021_174940.jpg 20181021_175047.jpg 20181021_174856.jpg 20181021_174940.jpg 20181021_175047.jpg IMG_0094.JPG IMG_0097.JPG IMG_0094.JPG IMG_0099.JPG
  2. Joseph Bautsch
    Dec 9, 2006
    1,113
    125
    Atlanta, GA
    It looks like someone took a piece of brass, pushed the end of it into the pivot and applied glue to hold it in place. Not a very good repair. It may even have worked to a degree, but given time it would certainly have failed. They probably would come off when put in clock cleaner solution anyway. They of course need to be removed and the holes re-bushed.
  3. D.th.munroe
    Feb 15, 2018
    494
    187
    BC Canada
    Yup just a small flat piece of brass jammed in and glued on. This is only some of the examples I've seen at least 10 clocks were done like this "professionally"
    Of course they are properly bushed now.
  4. Uhralt
    Uhralt Registered User
    4,846
    575
    I've never seen this, only a similar approach using solder instead of glue. If you see multiple of them it seems to be the specialty of a repair person somewhere in your area.
  5. lpbp
    lpbp Registered User
    NAWCC Star Fellow NAWCC Life Member NAWCC Member
    Aug 25, 2000
    2,904
    44
    I've seen it done with glue and solder, puts a strain on the train, and results in a grooved pivot on the end.
  6. Willie X
    Willie X Registered User
    12,774
    984
    Yep, you've got a local glue dobber there.
    Ask a few friendly questions and you can find out who it is. Willie X
  7. D.th.munroe
    Feb 15, 2018
    494
    187
    BC Canada
    Yup. I've asked a couple questions but havent found out who. I did find out he charged more to do that than I did to fix it, I found more pics of the work. Nice suspension spring there. Lol
  8. Willie X
    12,774
    984
    At least it's not made from the side of a plastic milk jug! Willie X
    NEW65 likes this.
  9. Joseph Bautsch
    Dec 9, 2006
    1,113
    125
    Atlanta, GA
    At least this week anyway. Never say never.
  10. TEACLOCKS
    TEACLOCKS Registered User
    Mar 22, 2005
    2,323
    77
    Clock service & repair
    Santa Rosa Calif.
    You don't have too get any solder off the plates.
  11. D.th.munroe
    Feb 15, 2018
    494
    187
    BC Canada
    Lol. No milk jugs yet .. Seen a few disposable razor blades as suspension springs. Yea glad they weren't soldered on.
  12. MARK A. BUTTERWORTH
    MARK A. BUTTERWORTH Registered User
    Jul 4, 2009
    2,330
    99
    Diistributor of movements and movement parts.
    Muscatine, Iowa 52761
    When folks do anything to avoid splitting the plates, it also means there was no pivot polishing either. Aside from cleaning the movement, pivot polishing and bushing are the two most fundamental operations in clock repair. It goes back to the saying, don’t learn the tricks of the trade, learn the trade.
    NEW65 likes this.
  13. Bruce Alexander
    Sponsor NAWCC Brass Member
    Feb 22, 2010
    6,885
    620
    Be sure to show your before and after pictures to the owner.
  14. David S
    David S Registered User
    Dec 18, 2011
    7,198
    245
    Brockville, On Canada
    This is a great thread. It shows that one doesn't need to mutilate the plates with Rathbun bushings, or solder. It says that yes glue (epoxy?) does work and seems to hold up to the lubricant and normal use. It is a shame we don't know what glue was actually used.
    David
  15. bangster
    bangster Moderator
    19,747
    413
    Ah yes. When I first got interested in clocks, and before I knew anything, I "fixed" an ovalled EW pivot hole with a bit of brass to support the pivot and superglue to hold it in place.
    It worked! Of course that was long ago and I'm not running that clock any more, so I don't know how well it's held up.:D
  16. D.th.munroe
    Feb 15, 2018
    494
    187
    BC Canada
    I will say it's much nicer than the old punch artist ones.
    As for the glue, the clear, I'm guessing some kind of epoxy, didn't stand up as well as whatever the silver colour glue is. Maybe a j-b weld type of product.
  17. R&A
    R&A Registered User
    Oct 21, 2008
    4,196
    107
    So are you telling us that you would consider using glue because it worked ?? Seriously
  18. David S
    Dec 18, 2011
    7,198
    245
    Well Michael, I have seen a lot worse, and this one is pretty much reversible and perhaps kept the movement out of the landfill. I like seeing different solutions to a problem. If this gets someone starting out, without a bushing system and tools, started, so be it.
    David
  19. Bruce Alexander
    Feb 22, 2010
    6,885
    620
    Whoever did this is evidently charging a healthy fee for it.
    To me that changes things a little. I think the OP should show before and after photos to the clock's owner and let him or her decide what kind of repair they previously paid for versus what they received (for less) this time around.
  20. Joseph Bautsch
    Dec 9, 2006
    1,113
    125
    Atlanta, GA
    It’s a very poor repair job. If only because it probably will not survive the chemical cleaning process.
  21. bangster
    bangster Moderator
    19,747
    413
    If I were in a Rathbun state of mind, I'd much rather do this. But with Superglue instead of glop.
  22. Bruce Alexander
    Feb 22, 2010
    6,885
    620
    Accumulation of dirt and debris? Pivot not evaluated and restored?
    What type state of mind is that bangster? o_O
  23. bangster
    bangster Moderator
    19,747
    413
    The state that surface bushing users are in. IF I were of a mind to do such a repair, for whatever reason, I'd do it that way. Come to think of it, I have done it that way...on a cheap alarm clock of my own, just to get it running. :eek:
  24. shutterbug
    43,425
    1,228
    I think Willie is correct that the person doing it is a local clock "repairman". Pitiful.
    NEW65 likes this.
  25. D.th.munroe
    Feb 15, 2018
    494
    187
    BC Canada
    I do normally show customers pictures of stuff like this, or at least show them before and after.
    I'd have no problem if someone did it to their own clocks, especially cheap alarm clocks ;) but to charge a customer professional rates to do it, yes pitiful.
  26. R&A
    R&A Registered User
    Oct 21, 2008
    4,196
    107
    Allot of what I see being told to others in here, is very similar to this repair.
  27. bangster
    bangster Moderator
    19,747
    413
    Oh, no doubt it's a half-assed repair that shouldn't be done on a customer's clock. Don't mean there's not a place for it. ;)
