Gilbert time and strike tambour
Discussion in 'Clock Repair' started by Joeclock, Sep 12, 2017.
  1. Joeclock
    Joeclock Registered User
    Jan 29, 2014
    34
    I had a case with the pendulum bob and hands, so I ordered a referbushed movement but it seems to be a little fast. I adjusted it as low as I could before it touched the bottom and it's close but it's still fast. Is there anything I could do or should I leave as is? I probably bought a similar movement that was slightly larger then what it had originally
  2. R. Croswell
    R. Croswell Registered User
    6,719
    32
    You already have a clock case married to a non-original movement so I assume this clock has no huge value. Perhaps the simplest thing to do is to cut out the bottom of the clock case under the pendulum to clear the pendulum and adjust it lower. Some clocks have such cutouts originally. A thinner suspension may help as well. Is the clock otherwise running strong with a good pendulum swing? One cannot regulate a clock that's not running properly.
  3. Joeclock
    Jan 29, 2014
    34
    it is running well. The movement was restored and had been tested on a stand before I got it. As of now I adjusted the pendulum up a little and over 10 hours it's maintained the time. I'll see if it holds after a day or so
  4. Bujumon
    Bujumon Registered User
    Oct 27, 2013
    Newbern TN
    Could you use a smaller pendulum bob?
    Perhaps lower the center of the mass...
  5. Willie X
    Willie X Registered User
    8,148
    32
    I would try Buju's suggestion first.
    Also, shortening the suspension spring 1/4" will raise the pendulum's effective length about 1/8". So, if your suspension spring looks a little long you can try this trick.
  6. shutterbug
    shutterbug Super Moderator
    34,652
    45
    Some pics of what you have would help ;)
  7. Joeclock
    Jan 29, 2014
    34
    #7 Joeclock, Sep 14, 2017
    As of now it's no longer fast but a little slow, so I don't think I'll have to change anything on it other than increasing the pendulum height to fine tune it. I'll try to see if I can get some pictures up.thanks for the suggestions
  8. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    737
    Science teacher, writer
    Lancaster, Ohio, USA
    Someone sells refurbished old clock movements? I didn't know that. Who?
    M Kinsler
  9. Joeclock
    Jan 29, 2014
    34
    #9 Joeclock, Sep 15, 2017
    It was an listing I ran across on eBay, I can't find the sellers info anymore, but he serviced the movement and tested it on a stand listing the pendulum weight used to test. He also adjusted it to to get it on time on the stand.
  10. shutterbug
    34,652
    45
    There are several people, many of them being members here, who refurbish and sell old movements. However there are other people who claim to do so, but wouldn't know a refurbished clock from a piece of junk. You have to ask specific questions to sort them out (they won't have or even know the specific answers).
  11. Joeclock
    Jan 29, 2014
    34
    Good to know, I went with this guy as he had some details on it rather than just saying it runs.
  12. kinsler33
    Aug 17, 2014
    737
    And then there's the traditional assurance from the local antique dealer: "It runs, but the key is missing."
    M Kinsler
Similar Threads - Gilbert strike tambour Forum Date
Gilbert Strike governor Clock Repair Sep 11, 2017
Gilbert 1903 time and strike mantel clock beat question Clock Repair Jun 14, 2017
Notch on Strike Side Main Spring on Gilbert Movement Clock Repair Jan 4, 2016
Gilbert Hall Clock "Chime Strike" reliability issue Clock Repair Sep 8, 2014
Pin in Gilbert Mantle Bim Bam strike Broken off Clock Repair Aug 21, 2014
