• We are aware of the performance issues with the forum. These are due to problems with Comcast's lines in the Columbia, PA area. We are working on the immediate issue with Comcast and are also working on a long term plan that will eliminate our reliance on Comcast. Thank you for your patience.
Gilbert Movement Lubrication
Dick C
Oct 14, 2009
1,906
107
What are the lubrication points on this portion of a Gilbert movement and what type of lubrication would you utilize?
This has been totally disassembled and cleaned.
TooManyClocks
Feb 6, 2019
246
62
64
I always put a just a bit of synthetic lube on the area where the maintaining power spring slides, as well as the pivots and the click. As you’ve noted, other opinions will vary!
John
Edit: I use something like Mobil 1 5-20 oil on areas like that. It seems quite sufficient, it will never gum up, and the maintaining power spring is pretty well enclosed so dirt never seems to get in there.
169,868
1,482,536
49,211
RenaissanceLawyer
2,965
