TickTockChuck
- Nov 17, 2022
- 5
- 0
- 1
- Country
Current rescue clock is a 1871-1934 Gilbert mantel clock (1912). It has Gilbert marked below the six on the clock face and stamped on movement. The real work is seen from the back side. It is completely missing and notice the plywood sound board, whoops. I have several questions.
1. Does anyone have a good and cheap source for tone wood (sound board)?
2. Does anyone know the construction of the back? Guessing two-piece basswood with a round metal cover over a center hole in the top piece.
3. Is this an original top? (The angular edge cut does not match other mantle clocks or the smooth curved bottom section of this clock. Plus, the top is held on by two metal brackets, another whoops for restoration.)
