I am new to the forum but have dabbled with clock repairing for years. Just retired so paying it more attention.
I have a Gilbert Clock that was not running. After watching dozens of videos on Ebay, and subscribing to some courses and buying some Horology books, I bit the bullet and took it apart. Cleaned it, and put it back together. In the process, I discovered (I think) why it was not running previously. It was obvious that the strike was bent such that it put pressure on the first wheel and kept it from turning. Easy fix, so I was hoping when I got it back together that it would run. Didn't happen. I believe the recoil escapement is not adjusted properly, but decided not to tackle that unless I got some help from the experts here. I have followed other threads that appeared to address the same problem, with the same escapement that I have, and if I am correct, I do not have the n 1/2 distance between the pallet forks or possibly the verge is too close to the escape wheel. I took a few pictures and a couple of videos and (hopefully) they are attached. I took one video with the verge removed just to show that the mainspring and other wheels in the time chain appear to be working properly and there should be enough force for the clock to run. That was not the case before I took it apart, so I think readjustment of the strike fixed the initial problem.
Thanks for any help you can give me. I was able to load pictures but not videos, so I put them in dropbox and the link is attached.Gilbert Clock videos and pictures
