Gilbert calendar clock
Discussion in 'Clock Repair' started by Kevin W., Apr 13, 2020.
  1. Kevin W.
    Kevin W. Registered User
    22,386
    345
    I just overhauled on Gilbert school house clock. The calendar hand advances . When i try to push the minute hand it wont move. I have another Gilbert calendar clock, which i have not touched. It has the same problem. I cant see or understand why this is happening. I will check too in a few repair books to try and find a diagram or some other help about this.
  2. Uhralt
    Uhralt Registered User
    4,809
    560
    Look for a frozen clutch.
  3. Willie X
    Willie X Registered User
    12,774
    983
    There is a 2:1 gear reduction gear that has a pin to activate the calander wheel. This pin can posibably go point to point with the 31 tooth calendar gear. The solution would be to check the calander location spring to see if it is controling the 31 tooth calandar wheel properly. If the location spring is properly adjusted the 'point to point' deal will never happen.
    I'm assuming you have checked the operation of the minute hand clutch.
    Dave T likes this.
  4. Kevin W.
    22,386
    345
    Thanks for the replies, i will check this out, not exactly sure what part is the clutch? I will get back to it in a while, going to work soon.
  5. Kevin W.
    22,386
    345
    Could someone point to a diagram showing the clutch for this movement? Thanks.
  6. Uhralt
    4,809
    560
    If you show us pictures of the movement, front, sides and back, we would probably be able to locate the clutch.
  7. Willie X
    12,774
    983
    The clutch action is between the small but thick spur gear directly behind the larger thin hour cannon gear and the larger thick gear behind it. This can be varied somewhat by increasing or decreasing the pressure applied by the spider washer directly behind the larger gear (just mentioned).
    Just take the movement out and watch this area as you rotate the minute hand. With a little studying all should become obvious.
  8. Kevin W.
    22,386
    345
    Thats the problem, i cant rotate the minute hand.
  9. Kevin W.
    22,386
    345
    When i put pressure on the minute hand it will make the escape work, but i cant set the time. Will have to look at this again when i have more time.
  10. shutterbug
    43,233
    1,191
    Gilbert's are famous for cracked pinion gears (between the plates on the minute arbor). Normally this causes the hands to flop around uncontrolled, but can also cause the gears to lock up. In those clocks, the clutch is often behind that pinion gear. I hope your problem is much simpler than that, but it wouldn't hurt to look closely at that area to see how the gear teeth are meshing.
  11. Kevin W.
    22,386
    345
    Thanks Shutt if the pinion was cracked, would the clock still keep time?
  12. shutterbug
    43,233
    1,191
    Good question. No, I think that would hose up the works. Must be the clutch ;)
    It still might be between the plates though. Let us know what you see.
  13. Kevin W.
    22,386
    345
    Thanks again Shutt, its a strange problem i think.
  14. Kevin W.
    22,386
    345
    Hello again. Here is a update on the problem i had. So i spent a while looking over the movement, trying to see if anything was binding. Could not see anything. So got ready to split the plates, restrained the m spring and let down the power. Just for the heck of it i tried the minute hand again.This time i was able to move it with my finger. So i fully wound the m spring and tried to move the minute hand again. It moved okay. So i really dont know what did stop it .
  15. shutterbug
    43,233
    1,191
    Strange! Glad it freed up though :)
  16. Kevin W.
    22,386
    345
    Thanks Shutt. I have another Gilbert, calendar movement, same problem, hope it will be easy to get going again. It needs a tear down, clean and oil. Perhaps that will help it.
