Hi All, Back again this a.m. btw, I do hope that my initial question did not give the impression that I was actually requesting a 'quote'... I realize that a myriad of issues can arise as a result of a broken mainspring. Over the years I have had numerous clocks break a mainspring, and one with obvious excess damage. One over-sized New Haven wall clock mainspring snapped as it was running and while I was sitting at my desk. It sounded like a gun had gone off in the room. One of the hands was actually laying at the bottom of the dial. There probably should have been supplemental damage in that instance, but there wasn't. When I requested a quote to replace the spring in this movement, that's what I expected, but with the caveat that I would be advised IF there was any additional 'unseen' damage, that would prevent the movement from working properly. One shop asked where the case was and then talked about various costs of springs? I simply asked for a quote to replace the spring, assuming he/she would use the correct and best quality spring available. I concluded my visit there fairly quickly. Because I had only brought the movement and pendulum/key with me, the other shop asked me to bring the hands in. Didn't try to wind it. I guess maybe then I will get a quote? He did note that there was no visible damage to the movement, i.e., gears, teeth, click spring(s). This particular movement was cleaned/refurbished a little over a year ago. At that time, the springs seemed to be in good shape and no need to replace either. I am fairly confident the spring just finally took its last quiet breath and gave out as quite a number of my clock movements have done in the past. I am in a new location with limited repair people in close proximity. 25++ years when I fell into the addiction of clocks, I purchased a fairly inexpensive but beautiful walnut Ingraham mantle clock. It drove me crazy that it would not chime on the appropriate hour/1/2 hour. I brought that clock into a local shop and he whisked it away to the back room. He returned about 8 minutes later with the clock chiming perfectly and said, 'that'll be $50.' I was so thrilled that I gladly wrote him a check! It's unfortunate that I learned soon thereafter exactly what he did to correct the chime strike... and to think he could have had my clock repair business for the next 20 years.
