Most visitors online was 1660 , on 12 Dec 2020
Thanks, I'll take a look!Hi,
This document can undoubtedly help you :
Amicalement GG![]()
When I try to set it going, it feels and sounds as if it's rubbing against something. It stops after one tick, I suspect it may need a new spring, but I don't know for sure at this point.The balance often gets blamed for a poor performing clock when it isn't at fault. Why do you suspect the balance?
This should help as well, thanks!Hi James, don't know if this the same document agemo is advising you to read but have at a look and see if it helps
That doesn't sound good. If it's rubbing on something, you should be able to see it. Is it interacting with the escapement OK, or can you see an issue there? Maybe the fork is not engaged with the roller correctly?When I try to set it going, it feels and sounds as if it's rubbing against something. It stops after one tick, I suspect it may need a new spring, but I don't know for sure at this point.
When I set it going (I've set the rollers so they are in the exact middle, looking at it straight on, as I read in the Hermle service manual) the rollers generally slip out of the fork. It only runs long enough to put the fork across back and forth once. So I think I can see an issue with it's interactions with the escapement/fork. I don't know if it should (and it may be hard to get a picture to show you) but the edge of the rod that attaches to the balance wheel, seems to rub against the wire at the bottom, So the rod sits at a slight angle I think, it is possible that the jewels could be worn, but I would've thought that at the end of each rod, it would be easy to see some sort of jewel that the wire passes through? And I can't see any.That doesn't sound good. If it's rubbing on something, you should be able to see it. Is it interacting with the escapement OK, or can you see an issue there? Maybe the fork is not engaged with the roller correctly?
I have removed it before, I have tried running it like that, I think the longest it ran for was maybe 5 seconds, when I got the clock the whole escapement needed put back together, and the balance needed installed too.You can remove the balance without messing anything up. Just be careful of the fork when you remove it. Then give it one full rotation and see how long it runs on its own. It should keep rotating a couple of minutes. If it doesn't, then you have an issue with the balance. If it does, then we can look at the fork position to see how that's doing.
Will he do one's that are international? Is it usually expensive to get them rebuilt?Then it probably needs to be rebuilt. David LaBounty does that, and is very reliable.
Why not write to him and ask him directly?Will he do one's that are international? Is it usually expensive to get them rebuilt?
