This is a German style, weight-driven wall clock that is a full 39" tall that was acquired locally. The widow of the last buyer didn't have any information as they had purchased it in a similar situation. The movement is unmarked, except for the numbers "190205". The movement is slightly trapezoidal. The dead beat verge is fitted with position adjustable pallets. The crutch is fitted with a threaded Beat adjustment.
Theblack dark brown painted case seems to be reminiscent of Mauthe clocks from the mid-1920's. It has a full-length door with beveled glass in the lower tablet. The sides are wooden with small movement inspection ports on either side. The gong mounts are unmarked.
Help identifying this clock will be highly appreciated.
[Edited color]
The
[Edited color]
