Geneva Stop on Carriage Clock
Discussion in 'General Clock Discussions' started by Robert Ryan, Mar 19, 2020.
  1. Robert Ryan
    Robert Ryan Registered User
    Mar 16, 2019
    88
    21
    Maine
    I am very much a beginner, but was surprised to find this in my French striking carriage clock. Any further information welcome. I am replacing the mainspring in the hope of making this wonderfully sounding clock more accurate. Thanks.
    ~Bob
  2. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    4,438
    95
    Devon
    Your clock was made by Couaillet and afaik it isn't especially unusual to find Geneva stop work on carriage clocks. Why do you think replacing the mainspring is required?
  3. Uhralt
    Uhralt Registered User
    4,329
    461
    Yes, not uncommon. Usually only on the time side.
  4. Robert Ryan
    Mar 16, 2019
    88
    21
    Maine
    Thanks jmclaugh. Appreciate the information. To my neophyte eye, I have cleaned it, oiled it, the platform escapement appears to lively with ample movement ....but it just wont run slow enough....gains about 10 minutes in 24 hours. The adjustment will not slow it down enough. So my very uneducated approach now is to replace the mainspring. When I removed the current spring it did appear to be set....meaning it didn't expand much after being removed from the barrel. I welcome your advice on the matter.
    ~Bob
  5. Robert Ryan
    Mar 16, 2019
    88
    21
    Maine
    Yes, it is exactly as you say....time side only. Thanks Uhralt
    ~B
  6. jmclaugh
    Jun 1, 2006
    4,438
    95
    Devon
    I'd think the problem lies in the escapement rather than the mainspring but I'm sure others on here will know more more about it than me.
  7. Robert Ryan
    Mar 16, 2019
    88
    21
    Maine
    If that is correct...then it's off to a professional....I have not the courage to deal with the platform.....at least not at the moment.....then why do I want to collect carriage clocks ....it's a mystery.
    What tells you that it is a Couaillet? Thanks again for the response.
  8. gmorse
    gmorse Registered User
    10,843
    1,361
    Retired from Xerox
    Hi Robert,
    If a lever escapement is showing a gaining rate, it may indicate that the balance amplitude is too low. One way to investigate this is to take a short video of the balance wheel in motion and then view in slow motion.
  9. Robert Ryan
    Mar 16, 2019
    88
    21
    Maine
    Thanks Graham, It's a cylinder escapement. Once I install the mainspring, I'll do just that...and I'll upload the video...if it doesn't fix the problem.
    ~Bob
  10. gmorse
    10,843
    1,361
    Retired from Xerox
    Hi Bob,
    Ah, that's different, a cylinder is a frictional rest escapement and will tend to compensate for changes in mainspring power because an increase in spring strength is balanced by the greater friction of the escape wheel teeth on the cylinder.
    Both the escape teeth and the cylinder can wear quite badly, so that's worth checking as well.
    You should still try to determine the balance amplitude once you've replaced the mainspring.
  11. Robert Ryan
    Mar 16, 2019
    88
    21
    Maine
    Thanks Graham, I'll be very curious what, if any, affect the new spring may have. You are probably correct in your assessment ....but working on cylinder escapements looks beyond my skillset...for sure.
    More later....
    ~Bob
  12. Ralph
    Ralph Registered User
    NAWCC Member Sponsor
    Jan 22, 2002
    4,739
    104
    The common issues with a gaining escapement rate are, distorted hairspring coils allowing a coil or coils to touch one another, magnetism, causing the coils to .attract and touch one another, or a piece of debris or dirt resting on/in the coils. All of these conditions effectively shorten the hairspring, and will cause a gaining rate, if it doesnt stop the clock.
    Also, if the hairspring it outside the regulator pins, dending, it might cause a gaining rate..
    Ralph
  13. Robert Ryan
    Mar 16, 2019
    88
    21
    Maine
    Hi Ralph
    I will attempt to inspect for conditions as you say. To the very untrained eye it appears to have the proper amount of arc....and also appears to have strong movement.....I've certainly seen worse.
    Thanks for your input.
    ~Bob
  14. jmclaugh
    Jun 1, 2006
    4,438
    95
    Devon
    The style of the arrow on the backplate Bob. As you say platform escapements should be left to repairers who are experienced with them which is more than most of us are, no reason not to collect clocks with them though, at least that's why I have some.
  15. Robert Ryan
    Mar 16, 2019
    88
    21
    Maine
    Thanks for that, jmclaugh. I do really enjoy carriage clocks....I've got 5...and 3 of them run.....not too bad an average. Some day I hope to get a repeater....but undercurrent circumstances...not going to happen.
  16. Robert Ryan
    Mar 16, 2019
    88
    21
    Maine
    Ralph,
    I spent some inspecting the escapement and the action of the hairspring. It appeared that the spring was stuck in the regulator pins. When I moved the regulator it distorted the shape of the spring. A little delicate fiddling with the pins seemed to free up the hairspring. Might that be the cause of my initial problem of gaining time? If I understand this correctly....essentially the regulator was unable to make any adjustments.....but that's just my very amateur theory. Anyway thanks for heading me in that direction...along with others.
    ~Bob
  17. Uhralt
    4,329
    461
    If the spring is stuck to the regulator pins the clock will run fast. The spring should freely oscillate between the pins so that there is a time where it doesn't touch any pin. It seems that something made the spring sticky, maybe some old oil? It might be a good idea to use some naphta on a Q-tip to carefully clean the spring without disturbing it.
  18. Robert Ryan
    Mar 16, 2019
    88
    21
    Maine
    Thanks Uhralt, will do...great tip.....
    ~B
  19. Robert Ryan
    Mar 16, 2019
    88
    21
    Maine
    Ah ha! The Q-tip and naphtha treatment did the trick. Over that last 24 plus hours the clock is keeping great time. Such a small but important remedy.
    Thank you Uhralt! ...and thanks to all with your help in sorting this out....very valuable forum, indeed!
    ~Bob
  20. Uhralt
    4,329
    461
    Glad I could help!
