i have a larger gear with 61 teeth that makes a full revolution 1x per hour... counter-clockwise, looking from the front of the movement.
i have a pinion with 15 teeth mounted on the shaft of a 4 RPH synchronization motor that needs to be mounted on the back of the movement because of space considerations... which would drive the gear the wrong way.
the question is: if i use another pinion as an idler gear to reverse the effective direction of the motor.... does it matter whether the idler gear has 15 or 12 teeth? or do idler gears change direction without having to worry about teeth counts?
hope that makes sense... thx!
