Gear train to convert a solar day to a sidereal day (or vice versa)
Discussion in 'Clock Construction' started by David Malphrus, Sep 1, 2014.
  1. David Malphrus
    David Malphrus Registered User
    Aug 27, 2014
    #1 David Malphrus, Sep 1, 2014
    Reference:
    Title: The new definition of universal time
    Authors: Aoki, S., Kinoshta, H., Guinot, B., Kaplan, G. H., McCarthy, D. D., & Seidelmann, P. K.,
    Journal: Astronomy and Astrophysics, vol. 105, no. 2
    It lists the conversion factor as: 1.002737909350795 for January 1, 2000. This value needs a "smidgen" of correction over time.
    The algorithm is 1.002737909350795 + 5.9006 10^-11 T - 5.9 10^-15 T^2
    Where T is the number of Julian centuries (consisting of 36,525 days of 86,400 seconds of dynamical time each) elapsed since JD 2451545 TDB.
    The elapsed time to current is 14 9/12 years or .1475 centuries for T meaning the present conversion is:
    1.002737909359498256638125 (for September 1, 2014).
    But, if this is used you will have an error of X in your gear train in 100 years, so why not use a conversion factor that is correct 50 years into the future. Then you would start with an error of .5X, end with an error of .5X and have (practically) no error at 50 years.
    September 1, 2064 = .6475 centuries for T.
    Conversion factor: 1.002737909388998911388125
    Now convert 1.002737909388998911388125 to un-vulgar/proper fractions for the gears while constraining the conversion to four fractions:
    My method produces:
    (233/359) * (346/317) * (358/304) * (363/302) = 1.0027379093889957827883714847908
    with a gear-train error of: 0.0000000000000031286
    Any thoughts, comments and/or corrections?
    --David Malphrus
  2. John MacArthur
    Feb 13, 2007
    322
    27
    "gear-train error of: 0.0000000000000031286"
    The sidereal day will likely change more than that over that length of time. It'd be a shame to have to adjust it......
    Johnny
  3. NigelW
    NigelW Registered User
    Jan 2, 2015
    356
    29
    London
    Sidereal time and mean time are surely related by a constant ratio, but doesn't the conversion to solar time involve an equation of time adjustment?
  4. NigelW
    Jan 2, 2015
    356
    29
    London
    Differential gearing to produce a solar time clock (theoretical exercise only)
    I am interested in the theory of equation of time clocks and understand that there are at least three methods for generating solar time: a cam, differential gearing and pendulum length adjustment.
    My paper exercise is to design a clock with a single escapement and pendulum but with two, separately driven trains - one showing mean time on a conventional dial and the other showing solar time on a second conventional dial (i.e. not just a + or - indicator or second minute hand), using differential gearing.
    I have been searching the net for clues on how to do this but have not got very far. Any pointers would be most appreciated.
  5. Tinker Dwight
    Tinker Dwight Registered User
    13,666
    No, Sidereal is relative to the stars. The equation of time
    is caused mostly by the elliptical orbit of the Earth relative
    to the sun. The Earth rotates at, mostly, a constant rate relative
    to an inertial frame of reference. The stars are an inertial
    frame of reference for all intensive purposes. The elliptical orbit is too
    tiny compared to the distant stars to have any effect.
    Sidereal and solar time are not the same.
  6. Tinker Dwight
    13,666
    Re: Differential gearing to produce a solar time clock (theoretical exercise only)
    What part are you having troubles with?
    Creating the cam or the gears?
  7. NigelW
    Jan 2, 2015
    356
    29
    London
    I know that sidereal time is different from solar time, but true solar is time based on the sun reaching its height at noon every day.
    My point is that sidereal time and mean time are pretty constant and can therefore be linked by a simple ratio but true solar time varies during the year because of the equation of time caused by a combination of the elliptical orbit of the earth and the tilt of the earth on its axis. I am currently interested in modelling this variation using differential gearing but have yet to find a design.
  8. Tinker Dwight
    13,666
    Lets try to keep to this one thread. It gets confusing if we have two threads
    on the same subject.
    To get some help on how to deal with things, look up tide machines. I think
    you'll find a lot of useful information because they are solving similar problems.
    Most of the newer ones have used Fourier transforms to create sine components.
    The summing method are about the same. It will be difficult to do seconds
    from the same pendulum but minutes and hours is not that hard.
  9. Allan Wolff
    Allan Wolff Moderator
    Mar 17, 2005
    614
    37
    Tulsa, OK
    I have merged the two threads on solar and sidereal time since they are very similar (and interesting!)
    Allan
  10. GregS
    GregS Registered User
    477
    Machesney Park, Illinois
    NigelW, you may also want to contact Mark Frank who has commissioned an extensive astrological clock. His website can be found here:
    www.my-time-machines.net
    I'm sure you can contact him via info found on his site.
    Cheers,
    Greg
  11. MartinM
    MartinM Registered User
    Jun 24, 2011
    2,995
    86
    El Dorado, CA
    Wow!
    Just...
    Wow!
