Hello, I recently acquired a GE Westminster chime self-starting clock. It has a Telechron B3 (model 59m31) motor.
I believe it is all original and in decent shape. The second hand moves when plugged in and the chimes work on the quarter hour. However, the chimes are slow and sometimes the barrel hesitates. The second hand moves, but at times in a jerky fashion. There is no noise/hum.
Would this suggest that the motor is fine, but the movement itself needs a good cleaning?
When cleaning such a movement, does one simply follow the mechanical movement methods of cleaning?
The label has handwritten numbers "G4/58 AW934J". Any significance?
Thanks!
Thanks!
