GB Torsion in for repair
Discussion in '400-Day & Atmos' started by Les Sanders, Oct 5, 2019.
  1. Les Sanders
    Les Sanders Registered User
    Apr 3, 2010
    740
    23
    Clock Repairman
    Sahuarita Arizona
    A customer GB Torsion clock. A couple of quick questions Age and the anchor pin. The serial # is 2281995 Freiburg. The anchor pin appears to be broken off Dang it! best way to remove and replace the anchor pin.
    MVC-001L.JPG MVC-002L.JPG MVC-003L.JPG MVC-004L.JPG MVC-005L.JPG MVC-006L.JPG
  2. Les Sanders
    Apr 3, 2010
    740
    23
    Clock Repairman
    Sahuarita Arizona
    Well I have it apart and the anchor pin had been glued in at some point, why not I will remove the glue and go from there. The old anchor pin is not threaded. Gives me pause was it ever threaded?
  3. etmb61
    etmb61 Registered User
    Oct 25, 2010
    2,450
    159
    Retired Avionics Technician
    Mascoutah, IL
    #3 etmb61, Oct 5, 2019
    Hi Les,
    About half of my Beckers have the pin soldered in place. Those that have not been disfigured have no exposed threads I can find. I tried to turn the pins out on two of those clocks with a pin vise but they would not budge. I think they are pressed in.
    I would say 1913-1914 for that serial number.
    Eric
  4. tracerjack
    tracerjack Registered User
    Jun 6, 2016
    1,010
    102
    Female
    Lodi, CA
    I wonder why the anchor pins are factory pressed in so tightly? I wouldn't think there would be that much stress on it. The 400 day Guide book says they can be drilled out if not hardened. Doesn't say what is to be done if hardened.
  5. Les Sanders
    Apr 3, 2010
    740
    23
    Clock Repairman
    Sahuarita Arizona
    Well they are hardened, they were pressed in to a brass collar so I am going to make a collar out of brass rod stock put a .040 anchor pin in and see what I have when it is finished.
  6. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    So I guess the alum bath method doesn't work on hardened steel?
  7. Les Sanders
    Apr 3, 2010
    740
    23
    Clock Repairman
    Sahuarita Arizona
    Not sure what the Alum Bath Method is?
  8. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    If you make a saturated solution of hot water and pickling alum (from the market spice section) in a glass container, you can soak a brass part with an iron part stuck in it to dissolve the iron part. The alum and hot water makes a weak sulfuric acid solution that eats away the iron.
    Alum - Wikipedia
    You would need to remove the collar form the arbor and soak just the collar.
    Eric
  9. Les Sanders
    Apr 3, 2010
    740
    23
    Clock Repairman
    Sahuarita Arizona
    Thanks Eric, I am getting ready to remove the collar I will try this method. Added a picture!
  10. shutterbug
    42,757
    1,118
    Be careful. You don't want to expose the arbor or pivot to the alum.
  11. Les Sanders
    Apr 3, 2010
    740
    23
    Clock Repairman
    Sahuarita Arizona
    I understand I have removed the collar from the arbor, but I have one question how strong should I make the solution?
  12. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    3,517
    125
    Aerospace Engineer (Ret.)
    San Antonio, TX
    I've never done this before, but found references to a "high" concentration of alum in water. Harry posted that he kept putting alum into the water until it wouldn't dissolve any more crystals:
    Kundo Pin Pallet Escapement
    Kurt
  13. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    As Harry said in Kurt's link, keep adding the alum until no more will dissolve. Also keep the solution hot and it works faster. You should see bubbles forming on and rising from the iron part.
    Eric
  14. Les Sanders
    Apr 3, 2010
    740
    23
    Clock Repairman
    Sahuarita Arizona
    So I fixed the anchor pin parts of the base are brass colored or plated, how to make them look polished? It would need to be a tinted clear like a toner.
  15. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    The top center pan of the base is brass plated steel, as are the centers of the support columns. The rest is all brass. If the plating isn't too damaged you can gently polish it. Yours really doesn't look too bad. Here is one I did some time ago that was much worse:
    Eric
  16. Les Sanders
    Apr 3, 2010
    740
    23
    Clock Repairman
    Sahuarita Arizona
    The rim part were the dome sits is rusted so I cleaned it up masked the polished surface and painted the rim part it looks great!
  17. MartinM
    MartinM Registered User
    Jun 24, 2011
    3,039
    95
    El Dorado, CA
    Nikolas makes a gold tinted lacquer that works well to give silver metals a brass look.
  18. Les Sanders
    Apr 3, 2010
    740
    23
    Clock Repairman
    Sahuarita Arizona
    Check out the finished product and let me know what you think!
    Wayne A likes this.
  19. shutterbug
    42,757
    1,118
    Looks good!
  20. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    Excellent!
  21. Les Sanders
    Apr 3, 2010
    740
    23
    Clock Repairman
    Sahuarita Arizona
    Thanks Guys getting ready for assembly and testing & adjusting.
  22. KurtinSA
    Nov 24, 2014
    3,517
    125
    San Antonio, TX
    Nice reflection of the columns in the surface of the base!
    Kurt
  23. Les Sanders
    Apr 3, 2010
    740
    23
    Clock Repairman
    Sahuarita Arizona
    Well back together but not running very well, I checked the suspension it is .0027 I thought it was around .004 anyone have that correct information?
  24. KurtinSA
    Nov 24, 2014
    3,517
    125
    San Antonio, TX
    Yes, from memory the GB should be 0.004".
    Kurt
  25. Les Sanders
    Apr 3, 2010
    740
    23
    Clock Repairman
    Sahuarita Arizona
    Thanks Kurt. A .004 it shall be!
  26. shutterbug
    42,757
    1,118
    If it's running way slow, then the suspension spring is the issue. Otherwise it has no effect on the clock running or not running.
    In fact, it should run easier with the thinner spring.
    Save that change for last. Check for beat and over swing first.
  27. Les Sanders
    Apr 3, 2010
    740
    23
    Clock Repairman
    Sahuarita Arizona
    The .004 is working great, running a 2 week test, I did trim the .004 about 3/16" the disc was dragging on the back screw. The spring that was on the clock was a .0027 I knew that was not correct!
