Gathering Pallet
Discussion in 'Clock Repair' started by JamesBB, Jan 24, 2020.
  1. JamesBB
    JamesBB Registered User
    Jan 19, 2020
    22
    This is the striking mechanism of a grandfather clock I'm repairing. Is there a piece missing? (Gathering pallet?)
    Many thanks for any help.
    James
  2. Uhralt
    Uhralt Registered User
    4,267
    448
    Yes, the gathering pallet is missing. One can see the empty square arbor to which it should be attached.
  3. JamesBB
    Jan 19, 2020
    22
    Thank you Uhralt. I'm guessing one has to make a replacement? Is there any help here on how to go about doing that?
    James
  4. Uhralt
    4,267
    448
    You can buy blanks that you would need to finish to the exact dimensions you need for your clock so that it meshes correctly with the rake. It is easier than making one from scratch.
  5. JamesBB
    Jan 19, 2020
    22
    Thanks, that's really helpful.
    James
  6. JamesBB
    Jan 19, 2020
    22
    How would one go about making such a tiny square hole in the gathering pallet blank? Are there files that small? Or does one broach it?
    James
  7. David S
    David S Registered User
    Dec 18, 2011
    7,174
    237
    Brockville, On Canada
    I have done this by using a square needle file as a broach and hammer it into a starter hole in the work piece. Hammer it in, turn it upside down and hammer the file out, insert from the other other side, repeat until the proper size is achieved.
    broaching in progress
    broaching in progress.jpg knocking file out knocking file out.jpg finished finished hand collet.jpg
    NEW65 and JamesBB like this.
  8. Uhralt
    4,267
    448
    The gathering pallets available here in the US seem to have a small round hole which could be "squared" using a very small square file or a jeweler's saw with a small blade. Commercially I think the square holes are made using a square broach that is pressed down, similar to the process how the square winding holes of clock keys are made. You could try to make such a broach, but I don't know how realistic that approach is.
    You could also "cheat" and use a piece of a pocket watch key with a fitting square and enlarge the round hole in the pallet to accept the piece of the key stem with a tight friction fit.
  9. JamesBB
    Jan 19, 2020
    22
    Thanks David and Uhralt; that's very helpful. The squared end on my clock seems tiny…and it's tapered so I'm guessing the piercing saw may be the best option.
    James
  10. Vernon
    Vernon Registered User
    NAWCC Member Donor
    Dec 9, 2006
    588
    44
    Gardener/Arborist
    JamesBB likes this.
