• Important Executive Director Announcement from the NAWCC
    The NAWCC Board of Directors is pleased to announce that Mr. Rory McEvoy has been named Executive Director of the NAWCC. Rory is an internationally renowned horological scholar and comes to the NAWCC with strong credentials that solidly align with our education, fundraising, and membership growth objectives. He has a postgraduate degree in the conservation and restoration of antique clocks from West Dean College, and throughout his career, he has had the opportunity to handle some of the world’s most important horological artifacts, including longitude timekeepers by Harrison, Kendall, and Mudge.
    Rory formerly worked as Curator of Horology at the Royal Observatory, Greenwich, where his role included day-to-day management of research and digitization projects, writing, public speaking, conservation, convening conferences, exhibition work, and development of acquisition/disposal and collection care policies. In addition, he has worked as a horological specialist at Bonhams in London, where he cataloged and handled many rare timepieces and built important relationships with collectors, buyers, and sellers. Most recently, Rory has used his talents to share his love of horology at the university level by teaching horological theory, history, and the practical repair and making of clocks and watches at Birmingham City University.
    Rory is a British citizen and currently resides in the UK. Pre-COVID-19, Rory and his wife, Kaai, visited HQ in Columbia, Pennsylvania, where they met with staff, spent time in the Museum and Library & Research Center, and toured the area. Rory and Kaai will be relocating to the area as soon as the immigration challenges and travel restrictions due to COVID-19 permit.
    Some of you may already be familiar with Rory as he is also a well-known author and lecturer. His recent publications include the book Harrison Decoded: Towards a Perfect Pendulum Clock, which he edited with Jonathan Betts, and the article “George Graham and the Orrery” in the journal Nuncius.
    Until Rory’s relocation to the United States is complete, he will be working closely with an on-boarding team assembled by the NAWCC Board of Directors to introduce him to the opportunities and challenges before us and to ensure a smooth transition. Rory will be participating in strategic and financial planning immediately, which will allow him to hit the ground running when he arrives in Columbia
    You can read more about Rory McEvoy and this exciting announcement in the upcoming March/April issue of the Watch & Clock Bulletin.
    Please join the entire Board and staff in welcoming Rory to the NAWCC community.
Garryflex for polishing pivots
Phil G4SPZ
Oct 18, 2018
583
91
67
Bewdley, Worcestershire, UK
Garryflex is a rubber compound impregnated with silicon carbide abrasive particles. The Museum, where I work as a volunteer horologist, use it for cleaning rust etc from cast iron and other artefacts, and they gave me a piece of the 240-grit material. A finer 320-grit version is available too.
I have recently been using it to polish clock pivots, where the arbor is rotated slowly in the lathe (or by hand) and the soft Garryflex block is gently pressed onto the pivot. I then push the pivot into some pithwood.
It works a treat and is less risky than burnishing, particularly with fine pivots found in 400-day clocks. Obviously this process won’t restore badly damaged pivots but definitely improves the surface finish of undamaged pivots. It will also impart a shine to and remove tarnish from steel arbors.
Phil
wefalck
Mar 29, 2011
602
51
Paris
I have been using a product called arc-o made by a (German) company Artiflex. Seems to be similar. Very useful indeed to clean metal parts without significantly altering their shape.
Reactions: Phil G4SPZ
Phil G4SPZ
Oct 18, 2018
583
91
67
Hi Mike, and hello again to you, Eberhard! I hope you’re both well.
I recall back in my childhood that you could buy a hard, abrasive rubber that was designed to clean rust and tarnish off the surface of the rails of model railway layouts, to improve electrical contact with the locomotive wheels, a problem well known to all railway modellers... I now recognise that product must have been Garryflex, or something like it.
I only mentioned its efficacy in polishing pivots because I’d never seen it discussed in clock circles before.
Phil
Reactions: MuseChaser
D.th.munroe
Feb 15, 2018
804
275
39
BC Canada
They are quite handy, Cratex is another similar rubberized abrasive.
People have suggested that one for pivots, I think Butterworth even sells the 1/8 rotary tool wheels of it for that.
Dan
Reactions: Kevin W.
karlmansson
Apr 20, 2013
2,668
137
Linköping, Sweden
Good tip!
Then of course there is the age old question of form and function in pivots. Abrading and polishing will make them pretty and run better for a while but will not create the same wear resistance as burnishing will.
I need to get somthing like Garryflex for finishing larger larts though. Seems to leave a nice finish!
Regards
Karl
wefalck
Mar 29, 2011
602
51
Paris
Karl is right, Burnishing with a steel burnisher not only polishes and smoothes the surface, but makes it actually denser - it is not an abrasive process.
Using Cratex, Artifex or whatever the brand name may be, rubber abrasive wheel does not lead to a geometrically well-defined surface. So I am not using it on any bearing surfaces.
Phil G4SPZ
Oct 18, 2018
583
91
67
I absolutely agree that burnishing serves a totally different purpose, and an abrasive will not restore a pivot where wear or damage is present. That’s not what I use Garryflex for; it’s just quicker and more effective than pithwood alone and improves the surface finish.
Phil
D.th.munroe
Feb 15, 2018
804
275
39
BC Canada
Cratex may be harder then, it would be quite hard to push a pivot into this suff.
My friend used to use a pen eraser for that, they were grey and white or pink and blue, and very cheap.
measuretwice
Jul 28, 2019
69
22
Toronto
Not sure I buy that it increases density but it does burnish and I agree with your conclusion. Its also, partially through burnishing and partially through material removal is going to impart flatness, i.e. a straight cylinder. A soft abrasive will not which I think is one of the objectives.
Material removal with a burnishers is very slight. Use some oil, burnish and inspect a drop of the oil. You'll see only the slightest hint of grey in it from the steel removed. I would estimate that the Cratex products I use for various things, in the various grits, would remove material at a much higher rate, perhaps magnitudes higher, than burnishing
Keep in mind, there isn't one level of burnisher. You can tune (or make) them to different levels. e.g. one made from a coarse stone will have more action than one prepared with a fine stone, etc. A fine one will hardly remove any manterial
wefalck
Mar 29, 2011
602
51
Paris
My understanding of 'burnishing' as a process is that surface roughness and surface geometry are smoothed out by 'forming' not by abrasion. This means that high points in the surface are displaced by pressure into lower areas (microscopically speaking), rather than cutting them away with an abrasive compound. This is why a hardened steel or carbide burnisher is used, that has been ground very flat as well. This displacement effect I meant to describe by 'increasing the density'.
measuretwice
Jul 28, 2019
69
22
Toronto
agreed. The burnisher although also cuts ever so slightly. Much less than the abrasive imo. SOP with a burnisher is that they are stoned so the lines run perpendicular to the axis, much like the teeth on a file. The micro burrs created by this do have a cutting action, which of course will be more or less depending on the coarseness of stone used on them. We're talking small stuff here, but the lines are there on a burnisher and they do (and are supposed to) remove a small bit of metal. After much use, you can freshen up a burnisher by stoning it again
I've got a Hauser power burnisher that uses a carbide wheel. Its, as far as I can tell, perfectly smooth. Its action must be exactly as you describe with seemingly no cutting action. But for the handheld long thin ones we all use, I believe they burnish and also do the tiniest bit of cutting (the "chips" are just barely apparent in the oil)
D.th.munroe
Feb 15, 2018
804
275
39
BC Canada
You can prove to yourself that burnishing work hardens a fine skin on the pivot, with a lathe and a graver, cut a pivot in some good steel, burnish it well, then try to cut some more from it.
karlmansson
Apr 20, 2013
2,668
137
Linköping, Sweden
I Always get a gray haze on my burnisher when I burnish pivots. So I Think I'm removing a Little bit of material. I'm also not sure if burnishing actually increases the density of the steel but I would like to learn. I am however positive that is does work harden the Surface and creates a very wear resistant and slick skin.
This is a pretty comprehensive study on the matter of finishes. Does not adress hardness though: http://abc.eznettools.net/D304430/X353088/Pivots.pdf
MARK A. BUTTERWORTH
NAWCC Life Member
Jul 4, 2009
2,428
135
Muscatine, Iowa 52761
We carry a series Of three discs, course, medium, and fine to go with the mandrels mentioned.. The disks are impregnated with carbide and work extremely well.
Copyright © National Association of Watch and Clock Collectors Inc (A 501c3 non-profit corporation). All Rights Reserved.
