G.M. Angem cuckoo clock movement.
Rod McLeod
Mar 3, 2019
79
I have cleaned and reassembled the movement, the first one of this manufacture I have seen. My problem is synchronizing the lift levers for the bellows with the lift lever for the hammer. When the movement stops, the short lever is partially raised so the bellow does not drop as it should. How do I synchronize the movement so it works properly. Thanks, Rod.
new2clocks
Apr 25, 2005
3,397
529
Pennsylvania
For the record, GM angem is not a make of clock or a type of clock.
GM angem is an abbreviation for Gebrauchsmuster Angemeldet, which is a German utility-model patent that has been applied for.
Use of the "GM" abbreviation (for Gebrauchsmuster ) is typically post WWII.
Regards.
Schatznut
Sep 26, 2020
312
136
SoCal
Picutres - lots of pictures- will help us help you, Rod.
Rod McLeod
Mar 3, 2019
79
What I need know is how the movement is to be assembled so that the cam, the pin wheel, and the count lever all line up so that the 2 levers and the strike lever are synchronized. The movement is the same as others which are shown online. Thanks, Rod.
Schatznut
Sep 26, 2020
312
136
SoCal
What brand of movement is it? Herr? Schatz? Regula, and if so, what model? Baduf? Schneider? Euramca? Rombach and Haas? Hekas? Trenkle Uhren? Other? We need to know this so we can help you.
Reactions: JimmyOz
Rod McLeod
Mar 3, 2019
79
It is a G.M. Angem 1 day cuckoo clock movement. Rod.
14,083
1,508
Rod,
I don't think anyone here can help you without a photo of what you have there, along with a close-up photo of the problem area.
46,719
1,913
Usually the lift cam is friction fit and can be moved without taking the movement apart again. It sounds like yours just needs to be nudged forward a little. Newer movements have a screw on the cam that can be loosened to allow it to turn.
POWERSTROKE
Jan 11, 2011
1,254
81
I did a Hubert Herr from the 50s and the cam didn’t seem to be friction fit. It wasn’t fun.
Rod McLeod
Mar 3, 2019
79
Rod,
There is no such thing as a G.M. Angem movement.
See my post, above.
You will need to provide pictures.
Regards.
1) On the back plate of the movement is "G.M. Angem"
2) On the Forum sites are MANY pictures of these movements.
3) Other folks have asked questions/made suggestions re these movements. So there seems to be much info about these clocks.
4) I just need to hear from someone familiar with these clocks to assist me.
Thanks, Rod.
JTD
Sep 27, 2005
8,666
735
It is not. See post #2. G.M. Angem. is not a make, as was clearly explained by new2clocks in his post.
Unless we see a photo of the movement no one can properly help. Otherwise you are just saying 'this is a movement by patent pending'.
JTD
14,083
1,508
Rod,
Are you unable to post photos? My crystal ball is still in the shop ... :)
With no real conversation, your thread will go dead pretty soon.
Rod McLeod
Mar 3, 2019
79
Rod,
Hi Willie, I noticed your threads as you assisted other folks with these G.M. Angem movements. (So there are G.M. Angem movements). You have offered replies to their asks. All I need is to figure out a way to synchronize the lever movements when assembling the movement so the levers drop properly when assembled. You had pictures of these movements. If I am wasting your time, you do not need to reply. Thanks, Rod.
46,719
1,913
Don't get riled, Rod. Folks want to help you, but we're shooting in the dark. Pictures can be added to your posts by using the "Attach files" box in the lower left corner of the posting box ;)
Rod McLeod
Mar 3, 2019
79
I opened the movement and rotated the cam wheel a tiny bit, reassembled the movement and bingo, the clock is working well. Thanks, Rod.
46,719
1,913
Glad you got it, Rod! We hope you'll stick around, and have another challenge for us :)
You never have too many clocks :D
166,231
1,448,295
86,745
Timemaestro
2,906
