Fusee power
Discussion in 'Clock Repair' started by Ron751, Jul 10, 2019.
  1. Ron751
    Ron751 Registered User
    Sep 2, 2011
    305
    Retired locksmith
    N. Massapequa, LI, NY
    The brass cable in my fusee movement recently broke while winding - there was no damage.
    I replaced it with the same length of gut & used a prescribed method to set the preload.
    The clock had previously run about 6.5 days.
    Now it runs about 4 days w/half of the fusee cone still wrapped.
    The preload procedure is one recommend by a member & has worked fine in all my movments.
    The spring is wound VERY tight now & I would not want to push it any further.
  2. novicetimekeeper
    Jul 26, 2015
    9,506
    539
    Dorset
    I would expect it to run 8 days, so that it can be wound once a week
  3. Uhralt
    Uhralt Registered User
    4,289
    450
    That sounds odd. When the clock stops, is there still tension on the spring? Can you describe your method of setting the pre-tension?
  4. Ron751
    Sep 2, 2011
    305
    Retired locksmith
    They usually run at least 8 days on a full wind - the barrel spring has to preloaded to make it go the full perod - 8 days or more
    Altashot likes this.
  5. Ron751
    Sep 2, 2011
    305
    Retired locksmith
    There is still some tension on the spring - but it doesn't appear to be enough....
    "I start with the fusee chain wound entirely around the fusee, except for a portion sufficient to reach the barrel. At this point, the spring is unwound. Then I give the mainspring barrel winding arbor a couple turns, and let the clock run until it stops, run down. Then give the winding arbor another turn, and set the clock running again. I do this until it runs 8 or 9 days. THEN I wind it fully at the fusee, and check the stop works when it is wound."
    This has worked on all my movements
  6. Uhralt
    4,289
    450
    Your method is fine in principle. However, before you set the pre-tension you should let the clock run down until the chain (or gut) is almost fully on the barrel and very little left on the fusee. Than put the anchor back on and put 1 to 1 1/2 turns of pre-tension on the spring. Then fully wind the clock. Now it should run for the full 8 days.
  7. Ron751
    Sep 2, 2011
    305
    Retired locksmith
    I'll try it but I am pessimistic about it.....
  8. Uhralt
    4,289
    450
    Let us know what you find.
  9. Ron751
    Sep 2, 2011
    305
    Retired locksmith
    I will !
  10. MartinM
    MartinM Registered User
    Jun 24, 2011
    3,031
    95
    El Dorado, CA
    When it stops at 4 days, how many turns does it take to let it down, fully?
  11. Ron751
    Sep 2, 2011
    305
    Retired locksmith
    After ~ 4 1/2 - 5 days . - it took 1.5 turns to let it down fully.
  12. Ron751
    Sep 2, 2011
    305
    Retired locksmith
    I followed Uhralt's directions- only I made 2 turns on the barrel instead of 1.5.
    It was crazy tight winding it after. I stopped before finishing - the last 2 grooves were "empty"
    I don't know if the additional turn on the barrel could have caused this ??
    Having to wind it that tight every 7 days seems a bit bizarre. My other fusees wind easily right to the end.
    We will seeo_O
  13. Willie X
    Willie X Registered User
    12,438
    841
    Sounds like your spring is too short.
    WIllie X
  14. Ron751
    Sep 2, 2011
    305
    Retired locksmith
    I wonder about that......o_O
  15. Uhralt
    4,289
    450
    The clock didn't run for a full week before the cable broke, so that's clearly a possibility. On the other hand, when you reduce the pretension for a half turn you should be able to fill the last two turns of the fusee because the diameter is small. The clock should then also be a bit easier to wind. You might even try a pre-tension of only one turn.
  16. novicetimekeeper
    Jul 26, 2015
    9,506
    539
    Dorset
    should the clock not be the same to wind throughout the whole spring? That's what the fusee is for in reverse.
  17. Ron751
    Sep 2, 2011
    305
    Retired locksmith
    Uhralt, That's what I'm going to do - one turn next cycle.
    Novice - you are right this is all so strange. With my old cable it wound smoothly til the end. I think this is a preeload issue...
    unfortnately, we have to wait a week for adjustments.
  18. Ron751
    Sep 2, 2011
    305
    Retired locksmith
    *OK - it ran for 8 days. I am going to give it one turn, as suggested. I think that will give the proper duration & solve the tight winding situation .
  19. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    3,040
    289
    Science teacher, writer
    Lancaster, Ohio, USA
    There's no way to get things upside-down in a fusee movement, is there? The winding torque should have been perfectly consistent throughout the wind
  20. Ron751
    Sep 2, 2011
    305
    Retired locksmith
    Yes, you are correct. I used too many turns of preload, which resulted in the over-tight winding.
  21. Uhralt
    4,289
    450
    Glad you got it solved.
  22. Probox
    Probox Registered User
    Oct 27, 2015
    187
    Public Housing Government
    Halifax Canada
    I enjoy working on fusee's and I totally agree with and use Uhralt's method. It''s easy and works. Some mainsprings need 1.5 winds, some need 2.0 full winds of pre-tension.
