Fusee cone assembly help needed....
Discussion in 'Watch Repair' started by Skutt50, Feb 22, 2017.
  1. Skutt50
    Skutt50 Registered User
    Mar 14, 2008
    2,898
    Gothenburg
    I am working on an old Fusee watch and am stuck on the fusee stop mechanism.
    I have not seen this type before and I am not even sure it is complete but hopefully someone here knows better what I have on my desk!
    There is no conventional fusee stop mechanism. Instead I found the parts in the picture below. Part marked B fell out when I disassembled the movement! I have a hunch that somehow part B should fit in D and work by stopping against A when the chain is close to full wind. The small spring C was found in the slot at D when I opened the lid, but I have no clue to how all of this is interacting!
    [​IMG]
    Anyone here who is familiar with this set up and can guide me to how they are assembled?
  2. gmorse
    gmorse Registered User
    7,292
    25
    Retired from Xerox
    Hi Skutt,
    Part B should be straight and not bent as far as I know, and just slide across the top of the fusee when the chain reaches it.
  3. Skutt50
    Mar 14, 2008
    2,898
    Gothenburg
    Super Graham
    I kind of expected you to help out in this. Many thanks.
    The movement came with a broken chain so the fuse slide may have been bent during the unwind! I will straighten it and see if I can get it back in action.
    Right now I have the pleasure of repairing the chain which includes making a new hook for the barrel. Whish me luck!
  4. Skutt50
    Mar 14, 2008
    2,898
    Gothenburg
    Just to let you know, it worked out nicely. Once I straightened the bent fusee slide everything made sense and it was easy to put it back together........ Everything looks great, the chain is repaired and I now need to make the barrel hook before testing the full movement.
    Thanks for your help Graham.
  5. gmorse
    7,292
    25
    Retired from Xerox
    Hi Skutt,
    These stop mechanisms seem to be commoner in French and Swiss fusees like yours than in English ones.
  6. klokwiz
    klokwiz Registered User
    NAWCC Member Donor
    Feb 4, 2009
    1,043
    WRENCH
    Annapolis, MD
    Skutt,
    Good job on restoring this to service. like yourself i had not seen this type of locking device. I wonder how many other versions there are? Maybe Graham could chime in?
    Joe
  7. Skutt50
    Mar 14, 2008
    2,898
    Gothenburg
    Interesting question Joe,
    I can't recall any other than the "conventional" arm that is pushed by the chain when close to full wind, and this!
    (After having fixed this I got a hunch I had seen one of these a long ago but I had no memory of it!)
  8. gmorse
    7,292
    25
    Retired from Xerox
    Hi Joe,
    Like Skutt I've only seen the usual English stop work with a pivoted lever under the top plate, and much less commonly this sliding bar mechanism. Oh, and I seem to recall seeing Geneva stop work on a fusee somewhere a long time ago, but that was on a clock I believe.
  9. Skutt50
    Mar 14, 2008
    2,898
    Gothenburg
    Hi Graham
    Geneva Stop Work on a fusee. Interesting.
    Do you remember where it was mounted? On the fusee I would imagine or the chain would live a dangerous life.
  10. gmorse
    7,292
    25
    Retired from Xerox
    Hi Skutt,
    Yes, it would have to be on the fusee!
  11. SKennedy
    SKennedy Registered User
    Jan 5, 2017
    81
    There's a slight variation to the 'normal' fusee stop work for watches/chronometers with reverse fusees. As it reaches the top of the fusee, the chain raises a sprung lever but instead of the cam/stop piece on the fusee cone butting into it in compression, the lever part has a slightly undercut end piece which is caught by the stop piece and puts it in tension. Its done this way simply because the fusee and barrel rotate in opposite directions in this circumstance rather than in the same direction as in an 'ordinary' watch.
  12. gmorse
    7,292
    25
    Retired from Xerox
    Hi Seth,
    I think this is a very elegant solution to that particular problem, which would otherwise need a more complicated layout.
  13. SKennedy
    Jan 5, 2017
    81
    I was looking at this movement a couple of days ago and remembered this discussion. Geneva stopwork on a fusee. 6 notches in the star to allow for 5 turns and the finger piece on the fusee arbor is a quite different shape to the more usual.
  14. Skutt50
    Mar 14, 2008
    2,898
    Gothenburg
    Thanks for the pictures SKennedy.
    This might been the solution Graham mentioned in his posting #8 above.
    Quite a nice solution to save the chain in a fusee movement.
  15. Michael Maddan
    Michael Maddan Registered User
    May 24, 2015
    50
    Having seen the Geneva stop for the first time in SKennedy's Post, I can only wonder: why didn't this excellent idea show up far, far more often...it seems an almost Perfect Design ! Michael.
  16. gmorse
    7,292
    25
    Retired from Xerox
    Hi Michael,
    I suspect it's mostly about "not invented here" as far as the English trade was concerned. Many Swiss watches with this stop-work that are seen in the UK have had it partially or wholly removed.
  17. Skutt50
    Mar 14, 2008
    2,898
    Gothenburg
    It just struck me that this design actually provides an improvement in functionality since you have type of a wind indicator!
Similar Threads - Fusee cone assembly Forum Date
Fusee Pocket Watch Hands Watch Repair Nov 2, 2017
English PW Harris and Sons fusee cone repair Watch Repair Oct 26, 2015
English PW Fusee cone repair help Watch Repair Apr 14, 2014
English PW help on repairing fusee cone ratchet Watch Repair Mar 14, 2014
English PW Fusee cone reassembly Watch Repair Aug 31, 2010
