French Stuckler
Discussion in 'Clock Repair' started by John Rausch, Aug 23, 2019.
  1. John Rausch
    John Rausch Registered User
    Mar 16, 2015
    35
    I am now preparing to clean/oil a French Japy Frere movement. I have it torn down except for the Strike Flirt Lever, which is "stuck" on the mounting post. Removing the taper pin was easy enough, but I am being overly cautious (you know how sensitive the French are) in trying to remove this lever. The top looks like a tiny gear, but it does not engage with anything and appears to be pressed on. below it the sleeve and lever appear to be one piece.
    Just wondering if someone who has worked on a Japy (or similar) can confirm that I just pry it off.
  2. shutterbug
    41,233
    814
    The pin indicates it should come off. A little pressure under the base should lift it off.
  3. dickstorer
    dickstorer Registered User
    Oct 19, 2010
    741
    Retired Military
    Hampton, Georgia
    That tiny gear is some ones idea of a washer to take up the space between the flirt and the taper pin hole.
  4. Fitzclan
    Fitzclan Registered User
    Jul 20, 2014
    568
    17
    Long Island, New York
    Yeah. The gear is not original to the movement, but looks like it does the trick. I’m sure it pulls right off.
  5. John Rausch
    Mar 16, 2015
    35
    And it did pry off... not easily, but it did. I was just a bit cautious because my French is so poor. Thanks for giving me the courage. I am a little wary of French movements because of war stories I've heard.
  6. shutterbug
    41,233
    814
    Yeah, they liked thin and very hard pivots. They break easily.
