Hi all
I am currently working on the a/ m clock. The pendulum that came with it is the typical starburst pendulum bob and rod associated with portico clocks but it is wrong. The Bob need s to be almost within the brass housing and well up out of view from below the clock dial which is obviously incorrect.
The length in French inches, as marked on the movement, is equal to 151.1 mm which would put the pendulum well in view below the dial as you would expect.
I am currently experimenting with a lighter temporary pendulum but it s still loosing a LOT of time.
Any suggestions on where to go with this ??
Eamonn
Eamonn
