Hi. A question for Shimmystep and his love for these movements. I have a French movement with gong, that was fully wound up, but wont run with the pendulum on, with out,the crutch runs very well, for the pass two days I have tried the pendulum and it stops running. I will have to let the springs down and check for bush wear, but nothing pointing to this problem at the moment. I have given the fork a tiny bit more width for the rod, any further suggestions. The movement will need a clean ,we'll over oiled. No makers name only a number 31207 and 14 at the bottom of the plate. The pendulum that came with it is 120mm from the hook to the let down pendulum centre. Any help welcome.
Most visitors online was 1660 , on 12 Dec 2020
