French Movement HELP and PARTS needed
Discussion in 'Clock Repair' started by Scott Andersen, Oct 14, 2011.
  1. Scott Andersen
    Scott Andersen New Member
    Oct 14, 2011
    I have a round French movement that is 75 mm in diameter with two trains.
    I need some parts from original movements or someone to help make me the parts I need.
    I have two pinion shafts that I need replaced or fabricated.
    The first one is on the front of the movement its has a very short shaft and it has the drive wheel that links to the minute hand drive wheel.
    The second one is the next to last shaft abnd wheel of the strike train...it links to fan control shaft....
    Im rebuilding this old clock and I cant seem to find the parts I need.
    I have been shopping ripoff ebay for months and everyone has the larger movement parts.
    This movement is only 75mm in diameter and I must admit has been a challenge for me to get these parts....
    I NEED HELP..... :>)
    I can send pictures of the parts if needed
    Thanks in advance
  2. Talyinka
    Talyinka Registered User
    May 14, 2011
    650
    10
    England
    Unfortunately, old French movements are not plug 'n' play so even if you do find a similar movement there is no guarantee that you can move parts from one to the other so your best bet is to make the parts, either by repairing the existing ones or by fabricating new ones on a lathe.
    Maybe photos showing the damage, and sketches with measurements, would help. I do have a selection of French movements I use for parts but in practice I almost always end up fabricating from scratch.
  3. Ed O'Brien
    Ed O'Brien Registered User
    Nov 30, 2009
    625
    25
    Retired, and now full-time clock repairs.
    Winter Park, FL
    If you have the parts that need replacing, and can provide dimensions, I have a pretty good stock of French parts removed from "junk" movements. Agreed that finding a match is difficult, but not impossible as I have found.
    Ed
  4. Mike Phelan
    Mike Phelan Registered User
    Dec 17, 2003
    9,836
    15
    West Yorkshire, England
    1. Is the minute wheel.
    2. Is the warning wheel.
    Why do they need replacing? If it's broken pivots, then they'll probably have to be repivoted. Arbors on these are glass-hard. :(
