French Marti Rack and Snail Strikes 2 at highest point on snail where one should be
clocks55
Oct 1, 2008
46
8 Hillcrest Lane Saratoga Springs NY 12866
I have lined up the 3 dots on the appropriate gears, and it strikes ok at 12, 12:30 but when it reaches the 1:00 position the rack falls all the way down and can not be gathered, so the strike runs completely down. At what should be one on the snail, the highest point on the snail, it strikes twice. I have also tried reindexing the motion work, but still get the same results. french marti movement.jpg Picture shows rack tail at highest point on snail with the gathering pallet about to grab two teeth.
harold bain
40,853
172
72
Re: French Marti Rack and Snail Strikes 2 at highest point on snail where one should
Wedge a screwdriver between the rack and the rack tail and make a small adjustment so that only one tooth is gathered. As for the rack falling all the way down, perhaps with the hands set up properly with a washer and pin on the minute hand, the rack will stay back enough that this won't happen.
13,666
72
The highest point should be 1.
It sounds like the rack and the rack tail are not right relative to each other.
After adjusting the angle between the two, you'll need to reset the
hour hand to match.
It is usually a tight fit between the rack tail and the rack but it
one should be able to adjust it.
I recommend removing it from the movement and determine
how much angle it needs to be moved by and make a template.
It is a tiny amount but you don't want to damage
the movement by slipping and it will be easier to get tools
around it.
45,035
1,513
To me, it looks like it's set to strike twice at 1:00. The rack tail looks to be a friction fit. Move the tail part away from the rack part and see what you get. TINY adjustments are the key. But that falling all the way down part is problematic. The tail is missing the snail completely.
clocks55
Oct 1, 2008
46
I thank you 3 gentleman for your excellent suggestions, as usual with this fine forum, the answers come faster than I can apply them, but I will let you know how things work out, this is the last issue left with this clock, I have been working on it for almost a year, and had given up on it many times, but the customer is pleasant and it has been a challenge.
ClipClock
Jun 20, 2013
1,593
Kent, UK
I always hesitate to make suggestions as I'm not the most experienced, but I have done a lot of French clocks, they're my absolute favourites :)
Yes it does look like its set up to strike two. I wonder if you still might have one more tooth you can rotate the snail, it looks to me like the rack tail is landing quite far along the snail (for a French clock). I find they like to barely make it onto the high point of the snail.
Re the dropping all the way down, French clocks seem to be little devils for the hour pinion edging forward unless the hands are firmly pinned. Are you sure this didnt happen in your case? Seems odd it would only drop all the way down for one strike.
On all the French clocks I've done the rack and rack tail are extremely firmly attached to each other and appear to be almost 'one piece'. I personally would not like to try to change that unless its a last resort!
One other thing I'd check is the rack hook, it needs to be firmly held on its squared arbor. I don't mean firmly pinned, I mean that the squared hole needs to be snug on the arbor. I've had inconsistent striking due to that being too sloppy and have had to tap lightly around the hole to rectify the problem
Good luck :)
clocks55
Oct 1, 2008
46
rack template.jpg I made a template after measuring how far the rack tail would travel for one tooth of the rack. I then opened up the angle between the rack and the rack tail by that amount. Now it works perfectly striking 1 at the highest point and 12 at the lowest point of the snail, and due to the changed geometry the rack no longer falls below the gathering pallet between 12 and 1, thanks again for all the help, kindest regards, Peter Elmendorf
harold bain
40,853
172
72
Good work, Peter.:thumb:
ClipClock
Jun 20, 2013
1,593
Kent, UK
Wow what an usual thing. Cool you managed to fix it!
Talyinka
May 14, 2011
650
10
England
Well done. This is the type of issue you come across all the time. The rack and the rack tail are lose on their centre, or the rack pin or rack pivoting centre are worn to produce excessive play. You often need to replace the cylinder enveloping the rack pin and solder or press fit in a new one.
Another thing to look our for is uneven wear around the rack pin causing the rack tail to miss the hour snail to one side or the other, again a common fault often discovered after carrying the clock in a non-vertical position and after putting it down noticing that the strike count is no longer correct.
45,035
1,513
:thumb:
13,666
72
In the picture, it looked to be exactly one tooth off. Rather than
wear, it looked to be misadjusted. That is why I suggested
moving rather than looking for warn parts.
